Amplifiers
This is a discussion on Amplifiers within the Yamaha Rhino Electrical Discussions forums, part of the The Garage category; To those of you running amps on your rhino, do any of you run non marine amps??? If so, where
Go Back   Yamaha Rhino Forums - Yamaha UTV Forum > The Garage > Yamaha Rhino Electrical Discussions
Notices
Old 09-01-2008, 11:18 PM   #1 (permalink)
funk6294's Avatar
Default Amplifiers
To those of you running amps on your rhino, do any of you run non marine amps??? If so, where are you mounting them, and any issues leaving the rhino out when it rains???
funk6294 is offline   Reply With Quote
Old 09-01-2008, 11:50 PM   #2 (permalink)
caliber1racing's Avatar
No I used an old Sony Xplod I had laying around. It's not water proof. I mounted it under the extra battery. I don't do to much riding in the rain/water so we will see how it holds up.
'08 Rhino 700
caliber1racing is offline   Reply With Quote
Old 09-02-2008, 12:02 AM   #3 (permalink)
funk6294's Avatar
I was thinking of that exact same spot, or mounting it on the inside of the under the dash.
Old 09-02-2008, 12:28 AM   #4 (permalink)
My other option was under the driver seat but I put a 10" subwoofer there instead.
'08 Rhino 700
Old 09-02-2008, 12:43 AM   #5 (permalink)
funk6294's Avatar
Looks pretty shoe horned in!!! I got my second battery there right now...
Old 09-02-2008, 07:48 AM   #6 (permalink)
Moderator
i have the metal locking center consloe, and i put and old alpine amp in the bottom compartment, keeps it pretty dust free and waterproof in there, but your limited on amp size, I have 4X75 mounted in there.
2007 Rotax dadyillac
Mush is offline   Reply With Quote
Old 09-03-2008, 10:05 PM   #7 (permalink)
I wouldn't mount it on the underside of the dash. It's on the 'wrong' side of the firewall and more likely to get debris and water from the tires kicked on it. After a mild ride, my outter firewall is always filthy. We mount under the seat and have had great success there. DEEP standing water is the only issue.
also, there is really no advantage to a marine amp. A marine amp has an anti corrosive coating on the board to stop salt air corrision. Great if you live in Pismo or ocean climates, useless for 99% of everyonelse. you still can get it wet or it'll short. Marine woofers don't do much either. Marine speakers have some value in a wakebaord boat but we haven't even had the need for those in 3years with our systems.
Trevor
SSV Works is offline   Reply With Quote
Old 09-03-2008, 10:16 PM   #8 (permalink)
Moderator
Bryan M's Avatar
Glove box works wonders for me .... yea!
WWRMD?
Can I be Kool like you?
Bryan M is offline   Reply With Quote
Old 09-03-2008, 10:20 PM   #9 (permalink)
funk6294's Avatar
Trevor
Trevor, thanks for the response, you hit on the exact concern that I have. I am thinking I will go for under the seat it it will fit.
Bryan, I already looked there and I dont think the amp will fit...
Old 09-03-2008, 10:22 PM   #10 (permalink)
Moderator
Bryan M's Avatar
Mines a 400 watt amp its pretty big and I still have room for a beanie or two and a few safety supplies...
Forum Jump
