Help !...please
This is a discussion on Help !...please within the Yamaha Rhino Electrical Discussions forums, part of the The Garage category; I went out to go start my rhino and Im getting a clicking noise from the battery compartment I narrowed
Go Back   Yamaha Rhino Forums - Yamaha UTV Forum > The Garage > Yamaha Rhino Electrical Discussions
Notices
Old 09-06-2008, 02:44 PM   #1 (permalink)
Trooper522's Avatar
Default Help !...please
I went out to go start my rhino and Im getting a clicking noise from the battery compartment I narrowed it down to some sort of relay, may be the solenoid not sure exactly but if you follow the positive lead from the battery it plugs in to this component....this is whats clicking I tried to start it with my battery charger and it still does the same thing....could it be my battery ? it has been on the low side.....please help guys, thanks
Trooper522 is offline   Reply With Quote
Old 09-06-2008, 02:45 PM   #2 (permalink)
goodguys75's Avatar
not 100% sure but it is probably a dead/bad batt, try to charge first and see if it turns over
JUST SAY NO TO C**K SNAPPING
IM RICK JAMES BIOTCH!!!!!
http://www.dumontduneriders.com/imag...ers/468x60.jpg
goodguys75 is offline   Reply With Quote
Old 09-06-2008, 02:49 PM   #3 (permalink)
Trooper522's Avatar
My charger says its charged and normally when it is low and I install the charger it starts imediatly.
Old 09-06-2008, 02:52 PM   #4 (permalink)
Check you connections make sure everything is tight
BiggJim is offline   Reply With Quote
Old 09-06-2008, 02:55 PM   #5 (permalink)
dirtysidedown's Avatar
I think dead/bad battery, But make sure your connections are good. Is your charger turning on?
dirtysidedown is offline   Reply With Quote
Old 09-06-2008, 02:59 PM   #6 (permalink)
Trooper522's Avatar
Thanks Jim I will check everything
Yep charge is on and shows full charge
Old 09-06-2008, 03:01 PM   #7 (permalink)
Is it a single click or a bunch of them? -click or click,click,click like someone dropped a bb on the floor?
Old 09-06-2008, 03:03 PM   #8 (permalink)
Head Ninja In Charge
bad connection, bad ground, or bad battery is my guess
wanna buy a fuckin phone?
max powers is offline   Reply With Quote
Old 09-06-2008, 03:04 PM   #9 (permalink)
goodguys75's Avatar
can you say that again? not sure what you mean.....lol
Old 09-06-2008, 03:04 PM   #10 (permalink)
Troop, do you have a volt meter??
COnnections--- both on batt, ground on engine block
hot wire on top of starter
sounds like a weak batt though
07fj is offline   Reply With Quote
Forum Jump
