Utvcrap.com cooling fan override
This is a discussion on Utvcrap.com cooling fan override within the Yamaha Rhino Electrical Discussions forums, part of the The Garage category; Utvcrap.com now has a cooling fan override switch relay kit... This kits is pre-wired and ready install with instructions ...and
Go Back   Yamaha Rhino Forums - Yamaha UTV Forum > The Garage > Yamaha Rhino Electrical Discussions
Notices
Old 06-01-2009, 06:39 PM   #1 (permalink)
Default Utvcrap.com cooling fan override
Utvcrap.com now has a cooling fan override switch relay kit... This kits is pre-wired and ready install with instructions ...and comes with a k4 sealed switch .... so now when you’re ready to started driving your rhino hard during the hot summer months or just hauling ass down the road .. You can reach over flip the switch and your cooling fan will run full time till you shut it down.... Price for the kit is $24.95
And they will be in stock June 1, 2009
WWW.UTVCRAP.COM
623-934-3070
Please understand we support many forums and cant keep up with Private messages or questions on the forum boards so If you have a question Please Call the Retail Shop 623-934-3070
If you have a Tech Question or Fabshop question please call me at 602-284-2430 Thanks Johnny
John@UTVCRAP is offline   Reply With Quote
Old 06-01-2009, 09:22 PM   #2 (permalink)
RhinoTalk.net
great Idea Johnny!
Prestige
Rigid E-series
Rugged Radio
Ron woods
Hapa is offline   Reply With Quote
Old 06-01-2009, 09:50 PM   #3 (permalink)
JoeyD23's Avatar
sick!
JoeyD23 is offline   Reply With Quote
Old 06-01-2009, 10:44 PM   #4 (permalink)
Double Trouble Hooks's Avatar
a MUST in AZ or summer dunin
Double Trouble Hooks is offline   Reply With Quote
Old 06-02-2009, 08:45 AM   #5 (permalink)
Powerplay's Avatar
Bad ass! Do you have them for the teryx??
Ninja police ????Y Hope you Got a Ninja warrant.... ...
Powerplay is offline   Reply With Quote
Old 06-02-2009, 08:47 AM   #6 (permalink)
KJSmith84's Avatar
is this for both the 660 and 700?
Fuck Haters
KJSmith84 is offline   Reply With Quote
Old 07-02-2009, 08:14 AM   #7 (permalink)
Default Engine Overheat
Is this a common problem with the Rhino. I posted a thread just yesterday 7/1 about a problem I am experiencing while out trail riding in the heat. I stated that it only happened once and wouldn't you know it last night I let the boys go out on the trails and they were riding on the dirt hills (slow moving, lots of load) and the engine overtemp light came on and the fan was not running. He turned the key off and on several times and the fan came on and the temperature light went out. Is this common or do you think I have a sensor or relay issue. I figured if anyone would know it would be you guys.
ghemmen is offline   Reply With Quote
Old 07-02-2009, 08:49 AM   #8 (permalink)
Head Ninja In Charge
sounds like your water temp sender is going bad, or you have air in the system and need to bleed it out.
wanna buy a fuckin phone?
max powers is offline   Reply With Quote
Old 07-02-2009, 09:04 AM   #9 (permalink)
Kinda what I thought. Dumb question but how do you properly burp the system
Old 07-02-2009, 09:34 AM   #10 (permalink)
on the waterneck where the hose comes out of the top of the engine, there is a little bleeder screw, open it up, fill radiator until water comes out, tighten up, warm rhino up with rad cap off adding water as necessary, once you see the water moving nice and radiator is full, put cap back on.
I usually jack the front end up a little to ensure all air is out while I do this.
Forum Jump
fan quit working! mx4life48 Yamaha Rhino Performance Discussions 4 08-22-2009 10:18 PM
Rotax cooling setups? Whats yours? Brian B Yamaha Rhino Engine Swap Discussions 15 06-08-2009 02:36 PM
TCP Fan Shroud V2PRODUCTS Yamaha Rhino's & Rhino Parts For Sale 7 04-29-2009 11:25 PM
Big bore cooling issues Xtremetoyzracing Yamaha Rhino Performance Discussions 19 02-28-2009 02:13 PM
Rhino Radiator with Fan HRT Motorsports Yamaha Rhino's & Rhino Parts For Sale 0 07-01-2008 04:40 PM
