Engine Overheat Issue
This is a discussion on Engine Overheat Issue within the Yamaha Rhino Electrical Discussions forums, part of the The Garage category; Lil Foot I can't find the circuit breaker. I think it may be bad according to your description. The boys
Go Back   Yamaha Rhino Forums - Yamaha UTV Forum > The Garage > Yamaha Rhino Electrical Discussions
Notices
Old 07-07-2009, 08:27 PM   #11 (permalink)
Lil Foot I can't find the circuit breaker. I think it may be bad according to your description. The boys called me today and the temp switch was at 240 and the fan would run for about 30 sec and off 30 sec. My service manual mentions how to test it, lists it in the wiring diagram but the cable routing doesn't mention it anywhere. Also noticed that my thermo switch 3 is slightly leaking on the plastic contact end. Maybe I should replace the whole wiring harness LOL.
ghemmen is offline   Reply With Quote
Old 07-08-2009, 02:41 PM   #12 (permalink)
Lil Foot's Avatar
Here's a link to Black Rhino's installation instructions for their PWR Radiator.... it shows where the breaker is, but on the '06 and newer models, it is located in the battery box behind the battery. (never knew there was a difference)
Hope this helps.
http://www.blackrhinoperformance.com...on%20Guide.pdf
Lil Foot is offline   Reply With Quote
Old 08-23-2009, 11:02 AM   #13 (permalink)
Where can I locate that gelpack?
RhinoRob is offline   Reply With Quote
Old 08-24-2009, 09:17 AM   #14 (permalink)
On the 06-07 its located inside the battery box. When standing on the passenger side of the UTV open the battery compartment and it is located in the wiring harness on the driver side of the battery compartment. It is a 2 wire (bullet spaids) circuit breaker with a black mesh insulator incased in a clear plastic shield. On the older utv's its located in the wiring harness next to the steering column right behind the dash. Hope this help.
Forum Jump
??engine? k5watt Yamaha Rhino General Discussions 0 03-08-2009 02:39 PM
Engine Ice Mush Yamaha Rhino General Discussions 8 10-27-2008 01:32 PM
Engine Cover SXSCustms Want Ads 2 09-23-2008 12:51 PM
Sidexside mag issue 17 here! mosslager Yamaha Rhino General Discussions 5 08-21-2008 03:20 PM
Side x Side issue 15 online! mosslager Yamaha Rhino General Discussions 22 07-15-2008 04:55 PM
