Engine Ice
This is a discussion on Engine Ice within the Yamaha Rhino General Discussions forums, part of the The Garage category; Well finally did the deed and cut my CVT cover in half to reduce the hot ass air coming in
| Notices |
Welcome to RhinoTalk.net, an online Yamaha Rhino enthusiasts community where you can join others from around the world to discuss everything from Rhino performance to maintennance, ask questions, or show off your own vehicle.
To gain full access to RhinoTalk.net you must register for a FREE account. As a registered member you will be able to:
- Participate within the forums
- Communicate privately with other enthusiasts from around the world.
- Post your own photos and videos or view user submitted images and videos.
- Gain access to our free classifieds marketplace to buy, sell and trade gear
- Take part in group buys and special deals on products, as well as learn about local rides.
All this and much more is available to you absolutely free when you register for an account, so sign up today!
If you have any problems with the registration process or your account login, please contact a RhinoTalk.net Staff Member. |
Maintenance, cleaning, etc. Off-topic posts should be put in the Off-Topic Forum. |
10-27-2008, 11:52 AM
#1 (permalink)
Moderator
Engine Ice
Well finally did the deed and cut my CVT cover in half to reduce the hot ass air coming in the motor area, also installed a water temp gauge, not done ran outta female spade connectors, and rinsed and flushed the cooling system to add engine ice. I want to make sure i do this right the 1st, i completly drained the system flushed it 3 times with h2o and vinegar 50/50 mix, then jacked the front of the rhino as far as it will go removed both bleeder screws (v-twin suckas) and filled until engine ice was coming outta the bleeders, closed and ran for aminute and kept refilling the rad. do i need to continue to bleed, do i run the motor while filling it up som the pump keeps it moving, it seems i have more air in there, proabably what is in the engine it'self..
come on rog i now you have mad tech ninja skills,
also glued on the inner door upholstery, black carbon fiber viynal, thanks jimmy z looks great. be repin in dumont this weekend.
2007 Rotax dadyillac
10-27-2008, 12:48 PM
#2 (permalink)
Run it until warm on gauge, let cool, check bleeders again, fill if needed.
Drive it around. let cool and check one last time, should be good to go.
10-27-2008, 12:58 PM
#3 (permalink)
Moderator
thanks rog,
10-27-2008, 01:09 PM
#4 (permalink)
When I installed my gauges it took 4 times to not see a drop in the level in the radiator after running it.
Powerplay-''This one time I was 69in wuth this fuckin smokin Ninja chick in cabo she was on top..she was swallowin my third batch of kids ....when I felt somethin hit me in the forehead ...looked like a Milkdud??? WTF...then another then another I finally looked up and saw one leaving her ass..I guess I shoulda smelled one before I ate one...''
10-27-2008, 01:24 PM
#5 (permalink)
Moderator
yeah it keeps dropin on me too, thats why i am paranoid now, and am asking.lol i had to leak a fkn half gallon of engine ice on the ground from my 2 bleeder screws outta parnioa
10-27-2008, 01:28 PM
#6 (permalink)
I just kept heat cycling the engine and topping off the radiator. I only used the bleeders twice. Been fine for 150 miles now
10-27-2008, 01:31 PM
#7 (permalink)
Moderator
do you run the engine with the rad cap off, or does that screw the loop system up? to heat cycle that is..
10-27-2008, 02:06 PM
#8 (permalink)
I just opened the to bleed and all so filled it up until it came out the bleeder. I'm running 50/50 colant and engine wetter. I added a fuidyne raditor with dual fans. motor was running around 210 all weekend. Fans turn on at 212 and turn off at 205. I never had any overheating problems weekend and it was 100 degrees out there. Thanks jimmy I also installed the door vinyl. Looks great.
10-27-2008, 02:32 PM
#9 (permalink)
I had the cap on
| Thread Tools |
| Display Modes |
Linear Mode
Powered by vBulletin ® Copyright © 2000 - 2010, Jelsoft Enterprises Ltd.
