Speed Governor
This is a discussion on Speed Governor within the Yamaha Rhino General Discussions forums, part of the The Garage category; I recently rolled my bone stock Rhino. There are not any aftermarket parts on it and it does not have
| Notices |
Welcome to RhinoTalk.net, an online Yamaha Rhino enthusiasts community where you can join others from around the world to discuss everything from Rhino performance to maintennance, ask questions, or show off your own vehicle.
To gain full access to RhinoTalk.net you must register for a FREE account. As a registered member you will be able to:
- Participate within the forums
- Communicate privately with other enthusiasts from around the world.
- Post your own photos and videos or view user submitted images and videos.
- Gain access to our free classifieds marketplace to buy, sell and trade gear
- Take part in group buys and special deals on products, as well as learn about local rides.
All this and much more is available to you absolutely free when you register for an account, so sign up today!
If you have any problems with the registration process or your account login, please contact a RhinoTalk.net Staff Member. |
Maintenance, cleaning, etc. Off-topic posts should be put in the Off-Topic Forum. |
03-04-2009, 03:06 PM
#1 (permalink)
Speed Governor
I recently rolled my bone stock Rhino. There are not any aftermarket parts on it and it does not have many hours on it either. I took it out again after my incident and now the top speed is 26 mph. It feels like the governor is kicking in and will just not let it go any faster. I don't know if there is a reset button for the fuel pump ar anything or if anyone else has had this problem. It was running perfect before but now this. Usually most of the driving is mountain road driving at pretty low to moderate speeds. Anything will help, I wanted to try this before I drop way too much money to take it in to a shop.
Thank you.
03-04-2009, 05:03 PM
#2 (permalink)
a couple of things, unhook battery for a while and try again.
unplug the rev wire, green one coming from under air box drivers side of motor through/ near oil filter/starter area.
maybe check the gas tank vent check valve near fuel pump.
take cover off of clutch and see if it spins up correctly, belt at bottom at idle and comes near top when revved up.
just some things to look at
03-04-2009, 05:04 PM
#3 (permalink)
Does it sound like it's not reving as hi, or does it seem like it's reving up and not going anywhere?
03-05-2009, 10:07 AM
#4 (permalink)
The engine does not rev out all the way. I don't remember what the RPM was when I was driving it. It almost seems like the black box is cutting out the ignition on it prematurely.
03-05-2009, 12:32 PM
#5 (permalink)
Super Moderator
My guess would be the rev wire....
2006 Rhino 660
BRP Stage 2 CDI
UTVCrap Sheave
LSR MTS +3 Mid Travel Kit
03-05-2009, 03:44 PM
#6 (permalink)
Rolling it over should not have affected the green rev wire. But it's such an easy test try it out and see if any difference. Does it take off normally up to that point, or is it all together sluggish?
03-05-2009, 04:46 PM
#7 (permalink)
well the switch has gotton sticky on many a rhino without rolling over, so rolling over sure could contribute to the problem possibly.
03-05-2009, 04:49 PM
#8 (permalink)
It takes off pretty normal. It does not seem to be sluggish. So it does not seem like it is a lack of fuel or air.
03-05-2009, 04:59 PM
#9 (permalink)
Didn't mean to sound like i was bashing your comment. I had not heard of that problem with the sticky switch before.
05-31-2009, 07:47 AM
#10 (permalink)
Mine is doing the same thing. Please let me know if you figure it out
| Thread Tools |
| Display Modes |
Linear Mode
Powered by vBulletin ® Copyright © 2000 - 2010, Jelsoft Enterprises Ltd.
