Temp Sensor
This is a discussion on Temp Sensor within the Yamaha Rhino General Discussions forums, part of the The Garage category; Just wondering where the temp sensor is on a 700.. trying to put a temp gauge on and just wodnering
| Notices |
Welcome to RhinoTalk.net, an online Yamaha Rhino enthusiasts community where you can join others from around the world to discuss everything from Rhino performance to maintennance, ask questions, or show off your own vehicle.
To gain full access to RhinoTalk.net you must register for a FREE account. As a registered member you will be able to:
- Participate within the forums
- Communicate privately with other enthusiasts from around the world.
- Post your own photos and videos or view user submitted images and videos.
- Gain access to our free classifieds marketplace to buy, sell and trade gear
- Take part in group buys and special deals on products, as well as learn about local rides.
All this and much more is available to you absolutely free when you register for an account, so sign up today!
If you have any problems with the registration process or your account login, please contact a RhinoTalk.net Staff Member. |
Maintenance, cleaning, etc. Off-topic posts should be put in the Off-Topic Forum. |
07-03-2009, 02:06 PM
#1 (permalink)
Temp Sensor
Just wondering where the temp sensor is on a 700.. trying to put a temp gauge on and just wodnering if the i can plug into the existing senosor spot..
thanks....
07-03-2009, 04:08 PM
#2 (permalink)
Head Ninja In Charge
you usually want to get the temps as the water exits the motor, at the waterneck where the bleeder screw is would be the perfect place to tap and die a sensor, the stock one is in the plug on the radiator
wanna buy a fuckin phone?
07-04-2009, 10:15 AM
#3 (permalink)
thanks....
If you want water temp,stick it in the rubber hose going back to the rad from the motor; if you want a combination of water & head temp ,since alum transfers heat, a good spot is where Max said
07-04-2009, 10:47 AM
#4 (permalink)
so your sayin if you tap a sensor in the waterneck it would pick up heat from the neck??? That is where I had mine and it worked fine, the gauge never got over 210, On my rhino motor, not my rotax.
07-04-2009, 12:19 PM
#5 (permalink)
so i m looking ontop of the engine where thee bleeder screw is by the thermostat? sorry guys i m lost here!
07-05-2009, 10:38 AM
#6 (permalink)
Max, if the sensor is at the alum neck on the head,it is picking up both head and water temp average; it works fine,I agree,but true water temp has to be in rubber tube just before the rad;I have both in my Teryx,and it reads about 6 to 8 degrees diff,being the water temp sensor at the tube at the rad is lower
07-05-2009, 12:08 PM
#7 (permalink)
gotcha
07-06-2009, 10:31 AM
#8 (permalink)
I have mine in the stock sensor location, if yamaha put it there then that is where it should be read from. and most water temp sensors are near the thermo housing, not in the radiator, those are only to turn on the fans. and it is this way on a rhino also.
07-06-2009, 02:36 PM
#9 (permalink)
Rog ,I agree with you; my comment was,at the stock location it is reading both combo of head & water,not that is wrong,but it is reading both and will make the reading higher
07-06-2009, 04:26 PM
#10 (permalink)
where is the stock location.. anybody?
| Thread Tools |
| Display Modes |
Linear Mode
Powered by vBulletin ® Copyright © 2000 - 2010, Jelsoft Enterprises Ltd.
