07 Rhino transmission not shifting - Yamaha Rhino Forums - Yamaha UTV Forum
This is a discussion on 07 Rhino transmission not shifting within the Yamaha Rhino General Discussions forums, part of the The Garage category; I have an 07 Rhino with about 350 miles. Just recently i was having difficulty shifting between geras (foward, reverse
Go Back   Yamaha Rhino Forums - Yamaha UTV Forum > The Garage > Yamaha Rhino General Discussions
Old 11-22-2009, 08:39 PM   #1 (permalink)
Default 07 Rhino transmission not shifting
I have an 07 Rhino with about 350 miles. Just recently i was having difficulty shifting between geras (foward, reverse etc,) It had been sitting for a couple of months so i thought it was just from sitting. After running awhile it got easier. Now when i have it in HI it doesn't seem to shift. It acts like it is in low all the time. With this problem is another strange thing. the speedo is way off. When i am doing about 30 the speedo is registering about 51. This all happend at the same time. I am hoping it is something simple. I removed the belt cover and the clutch seems to be working correctly. I need help and hope someone has the answer
dav4410 is offline   Reply With Quote
Old 11-24-2009, 09:58 AM   #2 (permalink)
KJM
your speedometer is probably on kilometers, you will need to reset it to miles per hour.
KJM is offline   Reply With Quote
Old 11-24-2009, 06:49 PM   #3 (permalink)
timc's Avatar
Like KJM said it sounds like your speedo is in KM/H not MPH. As for the shifting try turning the idle down some to see if that helps - if it idles too high they are a bitch to shift
2007 Sport Edition, 27" Bighorns, SS Wheels, Warn 3K Winch,Dynatek CDI, HW Sheave, HID's
timc is offline   Reply With Quote
Old 12-05-2009, 05:17 PM   #4 (permalink)
Did you check if linkage arent loose?
yamadodge is offline   Reply With Quote
Old 12-05-2009, 05:22 PM   #5 (permalink)
Head Ninja In Charge
07's are notorius for linkages coming loose, also to change your speedo, I believe it's the lower left button on the guage, hold it in and turn the key on then off and it should change to mph
max powers is offline   Reply With Quote
Old 12-06-2009, 10:42 AM   #6 (permalink)
yes it is the "trip/odo" button.
check the linkage at the motor and make sure the bolt is tight and put blue locktite on it.
idle it down some, prob shifts fine when motor is off???
07fj is offline   Reply With Quote
Copyright © 2000 - 2012, Jelsoft Enterprises Ltd.
