Head Gaskets problems
This is a discussion on Head Gaskets problems within the Yamaha Rhino General Discussions forums, part of the The Garage category; Does anyone have advice on aftermarket head gaskets? And what are the torque specs on the head bolts?
Go Back   Yamaha Rhino Forums - Yamaha UTV Forum > The Garage > Yamaha Rhino General Discussions
Notices
Old 02-05-2010, 11:06 PM   #1 (permalink)
Default Head Gaskets problems
blackrhino08 is offline   Reply With Quote
Old 02-06-2010, 12:22 PM   #2 (permalink)
cometic is the only headgskt i would use.
27 ftlbs for the headbolts.
BYCMOTORSPORTS
shonuff is offline   Reply With Quote
Old 02-07-2010, 05:10 PM   #3 (permalink)
I torque close to 35ft#'s or you can get a stud kit and go to 45ft#'s.
BiggJim is offline   Reply With Quote
Old 02-07-2010, 10:36 PM   #4 (permalink)
thats why your shit is always broke.
BYCMOTORSPORTS
Old 02-07-2010, 10:38 PM   #5 (permalink)
So some good and Torqued bolt cause valves to breakI musta missed that one somewhere....On a side note...I never had head gasket issues
Old 02-07-2010, 10:43 PM   #6 (permalink)
i was just playin playa.
but i do think 35 is too much, not really a head gskt issue. i think the stretch bolts work best at 27.
BYCMOTORSPORTS
Old 02-07-2010, 10:46 PM   #7 (permalink)
I think the issue is the head doesnt torque evenly because the 2 long 6mm bolts dont get torqued at the same time as the others....I did forget to mention I ran oversized head bolts from a camerybut I would have still over torqued the stockers just for good measure
Old 02-07-2010, 10:54 PM   #8 (permalink)
you are right, they dont torque evenly. that is why i torque them, run the motor over several heat cylcles, pull the valve cover, and retorque.
BYCMOTORSPORTS
Old 02-07-2010, 10:57 PM   #9 (permalink)
We actually built a torque plate so That you could torque the 2 6mm long bolts also with out puttin the valve cover on. We found there to be about an 8ft # difference between the outer 9mm head bolts and the inner 9mm head bolts. Since then everyone in my crew has used the torque plate.
Old 02-07-2010, 11:00 PM   #10 (permalink)
that is a great idea jimmy... but not everyone has a torque plate.
BYCMOTORSPORTS
Forum Jump
