temp gauge
This is a discussion on temp gauge within the Yamaha Rhino General Discussions forums, part of the The Garage category; looking for a sender to put in a water temp gauge.
anyone know a good place to buy one?
i
| Notices |
Welcome to RhinoTalk.net, an online Yamaha Rhino enthusiasts community where you can join others from around the world to discuss everything from Rhino performance to maintennance, ask questions, or show off your own vehicle.
To gain full access to RhinoTalk.net you must register for a FREE account. As a registered member you will be able to:
- Participate within the forums
- Communicate privately with other enthusiasts from around the world.
- Post your own photos and videos or view user submitted images and videos.
- Gain access to our free classifieds marketplace to buy, sell and trade gear
- Take part in group buys and special deals on products, as well as learn about local rides.
All this and much more is available to you absolutely free when you register for an account, so sign up today!
If you have any problems with the registration process or your account login, please contact a RhinoTalk.net Staff Member. |
Maintenance, cleaning, etc. Off-topic posts should be put in the Off-Topic Forum. |
07-23-2008, 10:03 AM
#1 (permalink)
temp gauge
i heard there was some that would install where the idiot light sensor is on the motor...that is what i'd like to use.
thanks
07-23-2008, 10:47 AM
#3 (permalink)
I bought my temp gauge from Weller. It came with a plate for the dash, autometer gauge, sender and a nice wiring harness. It made it a breeze to install.
07-23-2008, 10:55 AM
#4 (permalink)
rog and biggjim
how are the senders installed? do you have to tap into the water line?
07-23-2008, 11:48 AM
#5 (permalink)
Originally Posted by mx4life48
rog and biggjim
Stock location, and ground the stock pigtail so the idiot light stays off.
07-23-2008, 11:55 AM
#6 (permalink)
I bought a set up from BPR - Auto meter gauge and the inline hose sending unit -anyways my gauge will only read up to 160 and thats it.
it stops there. what is wrong? it has a good ground aswell and everything seems to be hooked up right.
Cant we all get along? lol
#7 (permalink)
why get rid of the light?? there is a bleder scrue on top of the water inlet.just install it there and its thick enoff to tap if your sensoer is to big. thats the way i would do it hell of a lot easyer
BUT ONLY A FEW CAN FLY
07-23-2008, 02:23 PM
#8 (permalink)
Well then why add a gauge??? No need for an idiot light that tells you it is overtemped , when if you have a gauge you see it coming, which is the point Terry. LOL
Kyle,, I would say the sensor is not matched to the gauge, ohms may be off. this has happened several times with BRP setups. Does the ground go to the motor where the Batt ground is connected??? if not try it there first and see if it changes.
Normal seems to be around 180-190 for the rhinos.
07-23-2008, 02:27 PM
#9 (permalink)
it is gounded to where my surepower battery seperator is gounded. BPR is suppost to call me and send me out a new set up.
I even tried putting a second ground on it - there is a spot on the in line that you screw in a small all thread with a nut to gound the in line part.
07-23-2008, 02:53 PM
#10 (permalink)
well if they have not sent it yet, try this, remove the ground wire from sensor and get a small hose clamp and clamp it to the body of the inline tube you put in and see if it changes. this would be a temp trial fix. if no change then I would still assume the sensor is wrong.
| Thread Tools |
| Display Modes |
Linear Mode
Powered by vBulletin ® Copyright © 2000 - 2010, Jelsoft Enterprises Ltd.
