Rhino 660 "cutting out" at higher RPM's - Yamaha Rhino Forums - Yamaha UTV Forum
This is a discussion on Rhino 660 "cutting out" at higher RPM's within the Yamaha Rhino Performance Discussions forums, part of the The Garage category; I have a Rhino that when I start accelerating it literally dog's or cut's out before it can reach maximum
Go Back   Yamaha Rhino Forums - Yamaha UTV Forum > The Garage > Yamaha Rhino Performance Discussions
Old 06-07-2009, 07:10 PM   #1 (permalink)
Default Rhino 660 "cutting out" at higher RPM's
I have a Rhino that when I start accelerating it literally dog's or cut's out before it can reach maximum speed (probably does it around 25-30 MPH). There are no major issues with the engine (oil is clean, no smoke, backfires, etc...). Has anyone experienced this before? It almost sounds like it loses gas or air for a second and acts like it is going to lose power. It happens no matter if it is cold or hot. Any help!!!
sonof12 is offline   Reply With Quote
Old 06-07-2009, 08:18 PM   #2 (permalink)
Head Ninja In Charge
start with the fuel filter, common problem, if that doesn't fix it, probably the pump
max powers is offline   Reply With Quote
Old 06-07-2009, 09:03 PM   #3 (permalink)
Also blow air thru the pick up tube. I have seen a goo like build up in them. Check that when you replace the filter....most likely you problem lies there somewhere
BiggJim is offline   Reply With Quote
Stock rhino steering column "SHORTENED" W/wheel & Quick Release stetler Yamaha Rhino's & Rhino Parts For Sale 7 09-29-2011 04:19 PM
Painted Rhino Plastic's "Cheap" Paulywood Yamaha Rhino's & Rhino Parts For Sale 7 06-29-2009 11:17 AM
check out this "rhino" nappahdog Yamaha Rhino General Discussions 6 12-02-2008 02:33 PM
is it possible to eliminate rhino suspension "buck" triple1050rhino Yamaha Rhino Suspension Discussions 17 11-26-2008 07:07 PM
"change" election "08" Rooster Fish Off-Topic Discussions 19 11-15-2008 01:58 PM
Copyright © 2000 - 2015, Jelsoft Enterprises Ltd.
RhinoTalk.net is an independent Yamaha enthusiast website. Content on RhinoTalk.net is generated by its users and RhinoTalk.net is not in any way affiliated with Yamaha Motor Corporation, U.S.A.
