2007 rhino 450 problems - Yamaha Rhino Forums - Yamaha UTV Forum
post #1 of 8 (permalink) Old 01-31-2014, 06:25 PM Thread Starter
hiccups and quits?
Rebuilt carb, no help
new fuel pump
new filter
new carb.
still no help.
checked fuel lines, and vacuum to pump.
new plug, cleaned fuel tank.
still hiccups and dies.
Help!!!
tsdas2 is offline
post #2 of 8 (permalink) Old 02-18-2014, 10:56 PM
stock's Avatar
if it runs with the choke on then your carb is still dirty if not you could have a bad cdi its by the battery
stock is offline
post #3 of 8 (permalink) Old 02-19-2014, 08:42 AM Thread Starter
Done some additional adjusting on both carbs. got it so it will idle better but it is still has sluggish throttle.
tsdas2 is offline
post #4 of 8 (permalink) Old 02-19-2014, 05:27 PM
stock's Avatar
you have to make sure the air jet is clean I would use a small wire or needle to make sure they are clear
stock is offline
post #5 of 8 (permalink) Old 02-19-2014, 06:21 PM Thread Starter
Sluggish 450.
One carb is brand new and I backed the air screw out from it's setting of 1 1/2 turns all the way to about 5 turns. still stayed sluggish. Thanks for the info. I may try a new pilot jet. It has a 20 in it now.
tsdas2 is offline
post #6 of 8 (permalink) Old 02-19-2014, 09:56 PM
stock's Avatar
sounds good your on the right track I always had to clean the carbs more than once
stock is offline
post #7 of 8 (permalink) Old 02-22-2014, 05:57 PM Thread Starter
Finally, I tried to find a bigger pilot jet locally but no luck, came home and got to looking at the old jet, it was a stock 20. Decided I didn't have nothing to lose so I tried a torch tip cleaner. A 14 thousands would go thru it so I took the next size which was 17 thousands and kept working till it would go thru, put it in the new carb and set the air at 2 turns out and it fired right up. No more spit back or stalling. Thanks for the advise.
tsdas2 is offline
post #8 of 8 (permalink) Old 02-23-2014, 09:59 PM
stock's Avatar
glad to here it was a dirty carb
stock is offline
