clutch problems - Yamaha Rhino Forums - Yamaha UTV Forum
post #1 of 19 (permalink) Old 02-23-2011, 02:24 PM Thread Starter
clutch problems
has anyone had trouble with clutch on 700.what i mean motors runs but when you put in gear it kills engine
craigp is offline
post #2 of 19 (permalink) Old 02-25-2011, 09:30 PM
USAFAMMO's Avatar
One way bearing really bad, and froze up?? Be sure the primary is assembled correctly, then run it with the belt off and watch how it operates. Make sure you have the cage on that covers the Primary clutch. It has to be something in the clutch system. Good luck.
USAFAMMO is offline
post #3 of 19 (permalink) Old 02-28-2011, 04:54 AM Thread Starter
i think i have narrowed down to wet clutch but is anybody selling just clutches.thanks again
craigp is offline
post #4 of 19 (permalink) Old 04-01-2011, 05:17 AM Thread Starter
clutch problem
ok have changed all bearings and seals from motor out.still kills engine when put in gear.i just tried without one way bearing being in and operated like it was supposed to. i am at witts end can anybody enlight me on what is the problem
craigp is offline
post #5 of 19 (permalink) Old 04-01-2011, 04:52 PM
USAFAMMO's Avatar
You said that you took the one way bearing out and it operated like it was supposed to.....Are you sure you didn't put the one way bearing backwards??? That would keep the motor from turning...I believe...
USAFAMMO is offline
post #6 of 19 (permalink) Old 04-02-2011, 05:45 AM Thread Starter
also fault codes 12 21 33 are showing. yes bearing has outside wrote on it and it has an arrow on it. i just don't know and i might as well scratch my head instead of a shop that charges 85.00 hr. thanks for any help
craigp is offline
post #7 of 19 (permalink) Old 04-02-2011, 06:47 AM
USAFAMMO's Avatar
You might want to try Chris at Benchmark. He posts on rhinoforums quite a bit but I'm not sure if he posts here. He helped me when I had my oneway bearing issue. Good luck.
USAFAMMO is offline
post #8 of 19 (permalink) Old 04-02-2011, 08:00 AM Thread Starter
Thanks I will
craigp is offline
post #9 of 19 (permalink) Old 04-03-2011, 12:17 PM
bender.chris5908's Avatar
Garage
is the bearing installed with the marks towards the clutch housing? i have seen these installed backwards alot
bender.chris5908 is offline
post #10 of 19 (permalink) Old 04-03-2011, 12:39 PM Thread Starter
clutch problem
i'm almost positive.there is an arrow on it that goes the way engine turns correct?
craigp is offline
