Speaker Noise - Yamaha Rhino Forums - Yamaha UTV Forum
post #1 of 13 (permalink) Old 08-20-2008, 06:29 PM Thread Starter
CommanderTalk.com
Speaker Noise
Ok so my friend has this humming (best way to describe it) through his speakers in his Rhino. Where could this interference be coming from? Has anyone else had to deal with this?
The humming stays the same regardless of volume or speed.
Rumor has it that it could be the CDI? I just do not know why the CDI would cause interference
I would think in would be something more like a ground or something, but what do all of you Rhino owners think?
ShootersRealm.com --> www.shootersrealm.com
CommanderTalk.com --> www.commandertalk.com
I support every man and women in the armed forces, I wish you all the best and thank you!
2008 Kawasaki Teryx | 840cc BBK w/ stage III cams | FST long travel and HD steering | Twisted Stitch seats | FST cage | Muzzy dual exhaust | Dynatek prog CDI | aFe intake | HiPer carbon fiber beadlocks | Goodyear MT/Rs | Crow restraints | SafeGlo LED and FO whips | NightOwl HID conversion | Edge series 40" LED lightbar | Fuego Dual HID lights | Dalton clutch kit and OD cover | Full audio | Navigation | Power steering | TrailTech Vapor computer | Factory UTV skids | Airtite Art custom paint | Maier plastics
dieselpowered is offline
post #2 of 13 (permalink) Old 08-20-2008, 06:31 PM
Sounds like a grounding issue to me.
post #3 of 13 (permalink) Old 08-20-2008, 06:35 PM
SXSCustms's Avatar
Noise
Yup could be a ground loop... make sure his ground(s) are solid, try jumping it to the battery.
SXSCustms is offline
post #4 of 13 (permalink) Old 08-20-2008, 06:35 PM
does he have a seperate amplifier as well?
shonuff is offline
post #5 of 13 (permalink) Old 08-20-2008, 06:36 PM Thread Starter
CommanderTalk.com
Yes there is an amp and a headunit.
He claims that he took out his aftermarket CDI and replaced it with stock and the noise went away almost completely.
I am just confused and not an electrical genious so I really do not know what it is.
I did tell him to check his grounds though.
post #6 of 13 (permalink) Old 08-20-2008, 06:40 PM
he needs to run his power and ground wire to the amp completely seperate of each other, running them side by side gives you a humm noise at all times. if that dosent work then bypass the amp and see if the noise goes away, if it does it might be an internal amp problem.
shonuff is offline
post #7 of 13 (permalink) Old 08-20-2008, 06:46 PM
i almost forgot, most amps have a gain control or volume knob on them. if it does make sure its not at its highest level.
shonuff is offline
post #8 of 13 (permalink) Old 08-20-2008, 06:58 PM Thread Starter
CommanderTalk.com
Good suggestions...I will have him try that.
Just not sure why the noise changed when the CDI was changed.
post #9 of 13 (permalink) Old 08-20-2008, 07:09 PM
you could also add a noise suppressor, they sell em at kragen.
most likely from a bad ground though.
post #10 of 13 (permalink) Old 08-20-2008, 07:33 PM
SXSCustms's Avatar
Some of the CDI are not properly shielded so they throw off some EMI, it happens.
cdi, interference, speakers
Speaker Boxes Unleashed UTV Yamaha Rhino Electrical Discussions 14 07-10-2008 11:24 AM
