Replacement cooling fan's - Yamaha Rhino Forums - Yamaha UTV Forum
post #1 of 5 (permalink) Old 07-06-2009, 10:43 PM Thread Starter
My cooling fan is fried. Which I found out while on a trail in alaska towing trailer for a friend. When my Rhino started overheating when all was said and done I only had 1/4 of my coolant left. luckly I found a clear and clean stream to fill the radiator with. Now I am wondering is there a aftermarket fan that I can used? I figure that there has to be a fan that is being used for a transmission cooler or something out there. I did a quick to see what a new one would cost and I am really not wanting to spend the $200+ on a fan that I dont use that much. Normal that air flow through the radiator is enough.
So, does any one know of an aftermarket or replacement fan that works on a rhino?
Craig
Kodiak, AK
"Drive it like you stole it"
kodiakrhino is offline
post #2 of 5 (permalink) Old 08-24-2009, 08:07 PM
My fan is toast as well! Did you find one that works? If so, let me know cause I've be looking! Thanks.
RhinoRob is offline
post #3 of 5 (permalink) Old 10-26-2009, 03:33 AM
Thanks for the suggestion, I wish it had worked.
glaunat is offline
post #4 of 5 (permalink) Old 10-26-2009, 08:18 PM Thread Starter
Sorry for the late response.
I ended up using a 10 fan from summitracing sum-G4901. I had to remove the quick connect from the old fan and attach it to the new fan. I am not a big fan of hacking OEM wiring harnesses. I had to drill holes in the radiator mounting tap so I could use the factory mounting hardware. It helps if you remove the radiator to facilitate this process. Took about 2hrs and a total cost was about $60. hope that helps
Craig
Kodiak, AK
post #5 of 5 (permalink) Old 01-04-2010, 01:20 AM
Thanks all for contributing to this thread. Lots to read in this forum but I like it.
huumingh is offline
fan
Knee replacement DUNE DUMMY 29 Off-Topic Discussions 38 10-26-2009 08:36 PM
Utvcrap.com cooling fan override [email protected] Yamaha Rhino Electrical Discussions 22 08-24-2009 09:11 AM
Rotax cooling setups? Whats yours? Brian B Yamaha Rhino Engine Swap Discussions 15 06-08-2009 01:36 PM
Big bore cooling issues Xtremetoyzracing Yamaha Rhino Performance Discussions 19 02-28-2009 01:13 PM
Crank Replacement Reese Yamaha Rhino Performance Discussions 17 12-15-2008 11:22 AM
