Ignition switch - Yamaha Rhino Forums - Yamaha UTV Forum
post #1 of 1 (permalink) Old 10-24-2009, 11:55 PM Thread Starter
Trooper522's Avatar
Ignition switch
Has anyone had any problems with their ignition switch ?...Went to the desert last weekend and on the last day noticed my ignition switch is hard to turn. Still starts and everything but when turning the key to accessory its alot harder to turn and also when you turn it to start the engine. I took the switch out and took it apart and noticed one of the spring loaded contacts was not toggling up and down. I lubed it and got it to work a little better but will probably have to replace it, its all in plastic casing and will only get worse. Just wondering if this is common and if you have replaced it ? also if there is there a better after market switch I can use or are you replacing with the oem switch.
Trooper522 is offline
