Seizmik Light Bar - Yamaha Rhino Forums - Yamaha UTV Forum
post #1 of 6 (permalink) Old 11-06-2009, 02:22 PM Thread Starter
Seizmik Light Bar
I am interested in adding a Seizmik light bar (Cabelas) to my 2009 rhino 700 Ducks Unlimited but I have two concerns.
- will the light bar fit with the stock roof on my rhino because the front of the roof is profiled about 2-4 inches forward.
- will running four 55 watt lights over tax the stock electrical system or can the system handle the increased power requirement.
- has anyone had any experience with this set up and what is your opinion.
Thanks everyone, I am a new member who is isolated in northern Nova Scotia, Canada. due to my location I am limited for rhino discussions as there are only a few in my area and everyone mainly keep them stock.
smithnr10 is offline
post #2 of 6 (permalink) Old 11-22-2009, 10:57 PM
Smiz's Avatar
Not sure if i can answer all your questions but I am running two extra PIAA lights on the front of my right and i have had no issues with it the best way to test is to stick them on there start your rhino turn everything on and put a meter on your battery and make sure it maintains voltage.
08 Rhino
MSD
Two Btothers Duals
Bored TB
Cam
11:1 Piston
26" Terra Crosses on 14"
Smiz is offline
post #3 of 6 (permalink) Old 11-25-2009, 04:02 PM Thread Starter
Thanks for the feed back
Thanks for taking the time to get back to me I truely appreciate it!
post #4 of 6 (permalink) Old 11-25-2009, 08:39 PM
I think that the stator's maximum output is 500 watts. 4 55watt lights will require 220 watts. That's nearly half of the system's capacity. You'll probably have your headlights on as well. And you haven't even supplied the motor any of the electricity that it needs. You can decide for yourself. If it was me, I'd reconsider.
Good luck,
Gil
2008 700, totally stock with a few things added here and there.
Gildo is offline
post #5 of 6 (permalink) Old 11-26-2009, 11:59 AM
I have one of these on my rhino and the kit works great. It will fit your stock roof because of the way that the mounting system works. You are able to slide the rack higher or lower on the cage depending on how you would like it. There's about a foot to go between.
mx_mayhem is offline
post #6 of 6 (permalink) Old 11-26-2009, 04:29 PM Thread Starter
Thanks for the reply, I have reconsidered as I bought 2 hella 55w lights and plan to use EMP's single mounts for the front uprights for the roll bar. This will only draw 110w so hopefully the 390 watts left over will be enough to run the rest of the systems.
