09 700 Speed Demon, WHY? - Yamaha Rhino Forums - Yamaha UTV Forum
post #1 of 3 (permalink) Old 04-25-2013, 03:10 PM Thread Starter
While in the process of tracking down an intermittent signal to the fuel system I replaced the air filter with a K&N, replaced the crank sensor and the ignition coil with an aftermarket unit.
When I can get it to run, it went from 40 MPH max to 65MPH! What Happened?
I am now looking at the wiring harness for the intermittent signal because I have replaced everything else. The OEM manual will arrive
shortly.
RandyRhino is offline
post #2 of 3 (permalink) Old 05-01-2013, 03:11 PM Thread Starter
shortly.
My Clymer manual came. The fule injector and the pump are on the same relay.
Wiggle the wires and no problem (after $500 parts and labor run around).
post #3 of 3 (permalink) Old 05-02-2013, 09:55 PM
dodgeboykim's Avatar
Seems to me there is a sensor/switch that when you put it in reverse it limits speed/rpm etc. A buddy of mine found his to be bad so he replaced it and that fixed it. Some of your symptoms sound just like his were.
Not sure where it is.
dodgeboykim is offline
