Clutching the Rotax - Yamaha Rhino Forums - Yamaha UTV Forum
post #1 of 19 (permalink) Old 09-04-2008, 06:38 PM Thread Starter
QwkRhino's Avatar
Question Clutching the Rotax
I'm planning on using the Dalton clutch, What weights should I run in arms. The steel ones or alumina ones. How's the Dalton spring work in these rhino. Does it stall up to about 2200 R.P.M.'s before in moves is that a little much or is it perfect for the sand? Also how hard is it to work on the clutch when it's in the Rhino with stock seat bases?
QwkRhino is offline
post #2 of 19 (permalink) Old 09-04-2008, 06:44 PM
I just did the dalton spring, and it is great, jumps rike-a grasshoppa off the line now. Only rode the sand in it once, and it felt good to me, but I'm just a rook in the sand.
post #3 of 19 (permalink) Old 09-04-2008, 06:49 PM
the low end torque is amazing. off the line is where it stands out.
post #4 of 19 (permalink) Old 09-11-2008, 05:31 PM Thread Starter
QwkRhino's Avatar
Which weights are you guys using?
QwkRhino is offline
post #5 of 19 (permalink) Old 09-11-2008, 05:51 PM Thread Starter
QwkRhino's Avatar
After reading the instructions I think I'm going with the steel rivets and green Dalton spring.
QwkRhino is offline
post #6 of 19 (permalink) Old 09-11-2008, 06:10 PM
sorry no help to you i had jay put the spring in when he did the swap.
post #7 of 19 (permalink) Old 09-11-2008, 11:09 PM Thread Starter
QwkRhino's Avatar
I think I'll call Jay tomorrow and ask. The instruction says, with heavy mud tire run no rivets in the replacement weights. Run steel rivets if you have a pipe and intake on stock tires at low elevation and run the aluminum if you are in high elevation with any tire over 5000 feet.
QwkRhino is offline
post #8 of 19 (permalink) Old 09-12-2008, 01:59 PM Thread Starter
QwkRhino's Avatar
Called Desertdog today, Jay says he runs the fingers with no rivets for the Rhino.
QwkRhino is offline
post #9 of 19 (permalink) Old 09-12-2008, 02:07 PM
I ran mine with no rivets. I could get 63 or so with 26" tires......69 on the speedo with stockers, but I NEVER hit the rev limiter in High range. I am guessing it was the clutching as I am sure the engine has the power!
VteGSR95 is offline
post #10 of 19 (permalink) Old 09-14-2008, 06:09 PM
warlock's Avatar
In my arctic cat with stock rotax I ran the steel arms no weight and the spring. Now with the turbo cat I run 2 kits with rivets in every arm and the spring and a secondary spring to.
warlock is offline
Rotax 800 d34thw1sh Yamaha Rhino's & Rhino Parts For Sale 18 11-10-2008 09:33 AM
Rotax ? fcobra-429 Yamaha Rhino Performance Discussions 32 11-09-2008 06:40 PM
Rotax Powerplay Yamaha Rhino Engine Swap Discussions 9 09-02-2008 05:49 PM
Rotax QwkRhino Yamaha Rhino Engine Swap Discussions 4 09-02-2008 05:40 PM
800 Rotax? GREGC Yamaha Rhino General Discussions 13 06-24-2008 07:57 PM
