quick question - Yamaha Rhino Forums - Yamaha UTV Forum
post #1 of 45 (permalink) Old 11-21-2008, 09:26 AM Thread Starter
greycj7's Avatar
quick question
Do you have to remove the front and rear diffs to remove the engine? I'm about to have to pull the engine due to a tranny problem.
05 Rhino 660-busted engine
greycj7 is offline
post #2 of 45 (permalink) Old 11-21-2008, 09:27 AM
KJSmith84's Avatar
no just remove the shafts
Cant we all get along? lol
KJSmith84 is offline
post #3 of 45 (permalink) Old 11-21-2008, 09:32 AM
what kind of tranny problem, you may not have to remove the engine to fix that.
post #4 of 45 (permalink) Old 11-21-2008, 10:04 AM Thread Starter
greycj7's Avatar
It's a really bad grinding noise that gets faster as you rev the engine. The Rhino will not move. I just took the belt housing off and looked at the clutches and can't see anything visibly wrong with them. I did not pull the clutches off yet.
greycj7 is offline
post #5 of 45 (permalink) Old 11-21-2008, 10:15 AM
1FAST06's Avatar
Move the front only.
New Rhino Informational Site rhinotalk,net
2006 Rhino- XMF 6" LT - XMF Front & Rear Gusset Plates - XMF Roll Cage - HCR Front Spindles - Gear One Steering Rack - BS Sand Seat - 6" Wide Fiberglass Body By Green Machine - Crow 5 Point Seat Belts - Weller Racing 720 - PRW Radiator - B&M Oil Cooler - Bronco Dry Clutch - 45mm HRC Carb - Ron Woods Single Exhaust - CDi Box - K&N Air Filter
1FAST06 is offline
post #6 of 45 (permalink) Old 11-21-2008, 10:22 AM
sounds like the weights turned in the sheave, you don't need to remove the motor, all work can be done in the car.
post #7 of 45 (permalink) Old 11-21-2008, 10:25 AM
1FAST06's Avatar
Mark is correct, if it is the clutch. You can do the work from the driver side of the car.
1FAST06 is offline
post #8 of 45 (permalink) Old 11-21-2008, 10:33 AM Thread Starter
greycj7's Avatar
Are you supposed to be able to move the front clutch by hand when it's in gear?
greycj7 is offline
post #9 of 45 (permalink) Old 11-21-2008, 10:46 AM
1FAST06's Avatar
Just a little
1FAST06 is offline
post #10 of 45 (permalink) Old 11-21-2008, 10:49 AM Thread Starter
greycj7's Avatar
It'll turn freely about a quarter turn then it stops. Then if you force it, it will slip then catch like it may be missing teeth on a gear or something.
greycj7 is offline
New DFR Quick Release Steering Wheel DRAGONFIRERACING Yamaha Rhino General Discussions 18 10-13-2011 05:12 PM
Quick Disconnects dieselpowered Yamaha Rhino Electrical Discussions 14 10-15-2008 10:04 AM
Good quick disconnects roger v Yamaha Rhino Electrical Discussions 19 10-08-2008 12:16 AM
Anybody running this type of QUICK RELEASE?? stetler Yamaha Rhino General Discussions 1 10-03-2008 05:50 PM
