thru shaft removal - Yamaha Rhino Forums - Yamaha UTV Forum
post #1 of 15 (permalink) Old 12-26-2008, 05:16 PM Thread Starter
thru shaft removal
What is the best way to remove the thru shaft? Do you have to remove the transmission?
THUNDERUSONE is offline
post #2 of 15 (permalink) Old 12-26-2008, 09:06 PM
Look at : 800 REAR MOTOR MOUNT:at yamaha rhino engine swap.and go to the last page.
controled force is offline
post #3 of 15 (permalink) Old 12-26-2008, 10:01 PM
mopar_enthusiast's Avatar
http://www.rhinotalk.net/forums/yama...r-mount-3.html
mopar_enthusiast is offline
post #4 of 15 (permalink) Old 12-26-2008, 10:57 PM Thread Starter
Who has actually done the thru shaft install themselves?
post #5 of 15 (permalink) Old 12-26-2008, 11:15 PM
warlock's Avatar
We do them here in phx.
warlock is offline
post #6 of 15 (permalink) Old 12-27-2008, 09:14 AM
QwkRhino's Avatar
You have too remove all your clutches, and you might need the special tool tool to remove the back half of the sheave. Then remove the back half of the CVT cover. After that remove the four bolts holding the trans together and separate it from the motor. Then you Can remove the three bolts that hold the oil seal in on each side. Once you have done that the through shaft will slide out.
QwkRhino is offline
post #7 of 15 (permalink) Old 12-27-2008, 09:25 AM Thread Starter
Thank you Q. Thats what I needed to know. I am at that point. I dont have anything to pull the fixed sheave off with. I will have to order one on monday. I was trying to rig up something to pull it with....but the 14mm bolts I have...have the wrong thread pitch.
post #8 of 15 (permalink) Old 12-28-2008, 02:02 PM
hey thunderusone go to homedepot or a bolt place and just buy a 14mm x 1.5 about 5 inches long with about 3 inches of thread and slide a 10mm bolt about 3 to 3 1/2 inches long with the head cut off in before the 14mm bolt and tighten the 14mm down. it should pop right off. and then after your done with the new thrushaft your going to need a 8mm x 1.25 about 2 1/2 to 3" long to screw into the secondary to spread it apart to allow for the belt reinstall.
bscottking21 is offline
post #9 of 15 (permalink) Old 12-29-2008, 09:34 AM Thread Starter
Headed to a supply house now. Great info!! Thanks!
post #10 of 15 (permalink) Old 01-02-2009, 11:08 PM Thread Starter
I finally got a chance to work on the conversion tonight for a few hours. Here are some pics of my headway. I used a 14MM X 1.5MM X 60MM with a piece of 3/8 steel rod 87MM long. I put the rod inside the primary shaft then put the 14MM bolt in and bumped it with the impact to remove the primary. You will also need the 8mm X 1.25MM X 75MM to put the belt back on the secondary upon reassembly. Once the CVT was off, I could remove the transmission. I used my rolling engine crane to hold the engine up at eye level to grind the case. I used black automotive touch up paint to mark the new shaft and then insert the shaft from the back with the front bearing, retainer, and seal installed on the engine. Where ever it touched, I ground lightly with one of my small porting bits on a 90 degree angle die grinder. I removed a little bit of material at a time. Each time I removed material, I would re-mark the shaft with fresh paint and do it again. I did this multiple times and it worked out perfect. It fits like a glove and I did not go through the oil passages. I used an led headlight on my head to light up the inside of the case while I was cutting. Thanks so much to Bscottking21 and Qwkrhino for steering me in the right direction!
Steering shaft diameter? JMS Yamaha Rhino General Discussions 1 12-25-2008 01:47 PM
needhelp with crank removal dirkgun Yamaha Rhino Performance Discussions 2 12-13-2008 09:51 PM
carb question needle jet removal Stevenast Yamaha Rhino Performance Discussions 5 12-03-2008 06:13 PM
steering shaft,drvrs floor,center floor hump triple1050rhino Want Ads 0 08-28-2008 10:48 PM
