rear drive shaft - Yamaha Rhino Forums - Yamaha UTV Forum
post #1 of 11 (permalink) Old 02-01-2009, 05:43 PM Thread Starter
lvautopro's Avatar
rear drive shaft
i'm getting a rattle at low load while driving sound like metal to metal thought it was the clutch took it apart looks normal on the primary couple of roller nylon bushings gone... i'll replace, but sounds loader than that... my frt driveshaft feels tight but the rear i can clunck back and forth by hand
seems a little play about 1/8 in play so i want to take out the rear drive shaft jay made check the u joints what is the easyest way to take it out? and what u joint do i get if worn?
I hate rattles
lvautopro is offline
post #2 of 11 (permalink) Old 02-05-2009, 11:56 PM Thread Starter
lvautopro's Avatar
pulled the rear diff and rear shaft came right off its tight hmmmmm
must be the in the clutch i 'll find it
post #3 of 11 (permalink) Old 02-06-2009, 12:09 AM
Trooper522's Avatar
does it happen when your braking or come to an abrupt halt ?
Trooper522 is offline
post #4 of 11 (permalink) Old 02-06-2009, 12:27 AM Thread Starter
lvautopro's Avatar
low speed vary little throtle when the motor is quite i can here it ... annoying as hell
i have another thought when i cut the clutch cover in half i removed the seal and put the half cover back on maybe its the cover bolt washers! i'll cut seal in half so its nice and tight and see if that gets it
post #5 of 11 (permalink) Old 02-06-2009, 10:22 AM
QwkRhino's Avatar
Has it always made this noise? My CVT did get alittle noiser after cutting the bottom of the cover. I did return half the seal after cutting it. Also make sure you use lots of grease and check both splins of the rear drive shaft and diff.
QwkRhino is offline
post #6 of 11 (permalink) Old 02-06-2009, 10:25 AM
is the plastic end cap on rear end, still on the rear drive shaft????
some lose the plastic cap and it will rattle against the nut inside the rotor that holds the input coupler in the diff..
post #7 of 11 (permalink) Old 02-06-2009, 11:20 AM
LBR
Administrator
LBR's Avatar
Did you notice it RIGHT after halving the cover? Could be that minor rattle is nature-of-the-beast 800 and with the clutch area more exposed, you now hear the noise. Maybe other swapped machine owners could answer this????LBR
LBR is offline
post #8 of 11 (permalink) Old 02-07-2009, 02:20 PM Thread Starter
lvautopro's Avatar
thanks all of you! i'll look in the areas discribed let you know when i find it
i'm going to grease the fitting in the rear drive shaft and splines think its in the drive shaft....also going to put the lower cover on first to see if its the clutch (i noticed 2 space washers for the clutch arm rollers blown out in the primary i'm going to replace) maybe?
i'll get it. let you guy's know what i found.
post #9 of 11 (permalink) Old 02-07-2009, 11:27 PM
warlock's Avatar
Well was it the joints.
warlock is offline
post #10 of 11 (permalink) Old 02-18-2009, 11:45 PM Thread Starter
lvautopro's Avatar
got back from dumont and i finally noticed the rear drive shaft was missing
the bolt to the through shaft put a bolt and washer in and i'll test this weekend in dumont let you know if that took care of it ........
Need Axle shaft, bed, front bumper for 05 Rhino cwbyinjeep Want Ads 0 01-04-2009 07:47 AM
thru shaft removal THUNDERUSONE Yamaha Rhino Engine Swap Discussions 14 01-03-2009 09:26 PM
Steering shaft diameter? JMS Yamaha Rhino General Discussions 1 12-25-2008 01:47 PM
Rhino front and rear seats with rear bracket ty8989ty Yamaha Rhino's & Rhino Parts For Sale 8 11-19-2008 09:31 PM
never let dogs drive! Powerplay Off-Topic Discussions 35 11-12-2008 01:11 PM
