Rotax cooling setups? Whats yours? - Yamaha Rhino Forums - Yamaha UTV Forum
post #1 of 16 (permalink) Old 05-18-2009, 07:17 PM Thread Starter
Brian B's Avatar
What are you guys running for cooling setups?
Stock thermostat? No thermostat?
Stock cooling fan wiring?
Fan on - key on?
Thanks!
Rotax Your Rhino
Brian B is offline
post #2 of 16 (permalink) Old 05-18-2009, 08:35 PM
QwkRhino's Avatar
Stock thermostat, Stock cooling fan wiring with over ride switch.
QwkRhino is offline
post #3 of 16 (permalink) Old 05-19-2009, 07:43 AM
all stock. with engine ice, wrapped header, and cvt cover mod
post #4 of 16 (permalink) Old 05-19-2009, 07:54 AM
pwr rad, having my exhaust ceramic coated,all rest stock, but may have to try some things with the new 840 if she runs hot
post #5 of 16 (permalink) Old 05-19-2009, 10:14 AM Thread Starter
Brian B's Avatar
What temps are you guys running at? "Fan-on" temp?
Anyone make a cooler thermostat for these engines?
Thanks!
Rotax Your Rhino
Brian B is offline
post #6 of 16 (permalink) Old 05-19-2009, 10:34 AM
LBR
Administrator
LBR's Avatar
FYI - In the Outlander manual I found some specs some time back - It seems that the fan was triggered on @ 208 degrees and off @ 203 degrees coolant temp. Another sensor read intake manifold temp and triggered the fan on @195 degrees and off @ 190 degrees.....or real close to those specs....LBR
LBR is offline
post #7 of 16 (permalink) Old 05-19-2009, 10:52 AM
QwkRhino's Avatar
Thanks!
Fan on cruzin you can get down to 185 but most of the time it wants to run at 210 have not found a cooler t stat the stock on opens at 165 degs f.
QwkRhino is offline
post #8 of 16 (permalink) Old 05-26-2009, 12:11 PM
NO8
ceramic coated headers, inside out. pc3 and next a extra fan to suck air into engine compartment.
NO8 is offline
post #9 of 16 (permalink) Old 06-05-2009, 04:34 PM Thread Starter
Brian B's Avatar
I hit 210 on my digital autometer yesterday before I shut it off. Fan didnt come on, and it was in limp mode when I turned the key back on.
The fan should definitely come on around 190. 208 is way too high!
Rotax Your Rhino
Brian B is offline
post #10 of 16 (permalink) Old 06-05-2009, 05:52 PM
LBR
Administrator
LBR's Avatar
Hi Brian - did you pull the code for limp home mode yet? Curious if it was for the temp - probably was. Several have posted that these monsters will throw the code if run fair hard and shut right down and not let idle for a couple of minutes to cool with circulation. I installed an Autometer 270 sweep Colbalt analog gauge with the sensor about 1' from the thermostat housing getting the hottest reading. Setting in the shop idleing, my fan kicks on @ 220 and off @209. When I unplug the engine temp sensor wire (pass side @ front cyl), fan comes on and stays on and will pull temps down to 155. When I got the CPU flashed Wednesday, I asked CanAm tech about the fan on @220/off @ 209 and was told is OK for the 800. If I start the cold engine with the fan on right away, it won't get above 140 in the shop. Ran it on my back roads and fan never came on once the whole time. Gad, so many different opinions starting to confuse LBR. LBR
LBR is offline
Rotax Clutch Setups THUNDERUSONE Yamaha Rhino Engine Swap Discussions 8 03-18-2009 09:08 PM
Big bore cooling issues Xtremetoyzracing Yamaha Rhino Performance Discussions 19 02-28-2009 01:13 PM
Rotax Air cleaner setups lvautopro Yamaha Rhino Engine Swap Discussions 21 12-23-2008 06:44 PM
Whats up Spango Member Introductions 15 11-11-2008 07:24 AM
Whats next?? stetler Off-Topic Discussions 14 11-03-2008 09:37 AM
