crank split!!!!! hell no - Yamaha Rhino Forums - Yamaha UTV Forum
post #1 of 15 (permalink) Old 04-09-2010, 11:36 AM Thread Starter
well tried to split today heated up with oxy torch and had a hyd splitter and still no split can anyone please tell me how to spit the crank i have access to all tools presses just aint got the knowhow......
also does anyone know if the raptor crank is the same as the rhino?
helpp! help! help!
gandypandy is offline
post #2 of 15 (permalink) Old 04-09-2010, 12:16 PM
The best way I have found to split a crank is to take it to someone who knows how to do it. sorry I am not more help
post #3 of 15 (permalink) Old 04-09-2010, 01:27 PM Thread Starter
ra ra ra ra
Yep prob right but i do like to try first not only to save costs but get the satisfaction that i actually completed a difficult task! I just need guidance now i have seen on net hotrods crank complete but dont know what the +4 means????????
As you can gather i an a newbee into all this!
so if anyone can help please advise
post #4 of 15 (permalink) Old 04-09-2010, 01:56 PM
My guess is that a +4 crank is stroker crank +4mm. I do not know the c.c. gain on a 4mm stroker crank but am sure someone here does.
bigdjvp is offline
post #5 of 15 (permalink) Old 04-09-2010, 05:32 PM
if you are going to split the cases and add a +4 crank, you might as well add a 102mm piston. that would make it a 719cc engine.
the crankshaft on the raptor is not the same as the one on the rhino.
shonuff is offline
post #6 of 15 (permalink) Old 04-10-2010, 12:26 AM Thread Starter
Originally Posted by shonuff View Post
if you are going to split the cases and add a +4 crank, you might as well add a 102mm piston. that would make it a 719cc engine. Yes i have seen the kits on ebay sleve,piston,crank,and gasket set 500 us dol seems quite reasonable as i have just got a price from yamaha over here and for the stock crank and bearings they want 1530 us dol.
Thanks for that info!
post #7 of 15 (permalink) Old 04-10-2010, 12:28 AM Thread Starter
(dont know why it added onto last post)
post #8 of 15 (permalink) Old 04-10-2010, 12:40 AM Thread Starter
I forgot to mention all the shops that i have called over here say they never split the cranks they just fit crank kits in and throw old crank away!!!
mmmmmm if i could find a easy method i think i have just come across a good buisiness!
another silly question from a brit
I have heated the crank up to red hot with oxy torch am i right in saying because this part is a moulded steel the molecular structure changes when heated basically making it weak? The reason why i ask this is the even if i get it off i dont want to put this back in in case it throws the piston through the head.......
And before i get a ribbin from pips i looked this up online as i wanted to know how much cast expands heated apposed to machined ie the centre pin.
my bug has only just covered 800 miles but they wont do it under warrenty because i have changed exhaust, modded carb, installed cdi unit, all of which the shop sourced for me!!!! what a kin wan*er's they are........................................
post #9 of 15 (permalink) Old 04-12-2010, 12:21 PM
I would not get a "hotrods" crank, they are terrible.
I would also not do a stroker motor in a rhino.
e:mail [email protected] or call him at 760-484-0986
best in the Biz for RHino motors. he can get you a crank and other performance parts that will last and give great power.
Rog sent ya
post #10 of 15 (permalink) Old 04-12-2010, 12:44 PM Thread Starter
splitting crank in uk yipeeeeeee
so update on the crankeeee
I have found a company that will split the crank and rebuild and balance for
150 so happy days for me.
Some idiot at my work has tidied up all the parts that i had laid out in order
I now have a big box of cogs n bits tring to look on manual to find out where they go the only thing i cant place is tw thin metal shims about 3/4 inch 3mm thick TWO OF THESE any idea??
MISSION IMPOSSIBLE I THINK?
