exhaust header problems - Yamaha Rhino Forums - Yamaha UTV Forum
post #1 of 11 (permalink) Old 10-04-2008, 10:45 PM Thread Starter
I'm having a problem on my 2006 660 I keep breaking the header pipe. its cracking on one side about 3"back from were it mounts to the motor. I have had it welded twice but I'm just curious if anyone else has had this problem.
dontherhinoman is offline
post #2 of 11 (permalink) Old 10-04-2008, 10:47 PM
aftermarket or stock??
post #3 of 11 (permalink) Old 10-04-2008, 10:52 PM
I have never seen a stocker break.....I have seen multipul aftermarket pipes break. I dont think yopu will get a weld to hold...better off buying a new header. When you put it on make sure the exhaust is in a relaxed position
post #4 of 11 (permalink) Old 10-05-2008, 08:07 AM Thread Starter
stock
this is the stock pipe.I checked to make sure engine mounts were good and they are. I see a lot of aftermarket pipes available but I want to keep the same sound level of the stock exhaust.
post #5 of 11 (permalink) Old 10-05-2008, 01:52 PM
Could be running lean causing them to get to hot.
post #6 of 11 (permalink) Old 10-05-2008, 02:42 PM
dirtysidedown's Avatar
Good call Max! I didn't think of that! Also when you bolt the exhaust on do it evenly and not in sections. Meaning tighten all the bolts a little at a time instead of tightening where they mount to the head and then cranking down on the muffler etc.
dirtysidedown is offline
post #7 of 11 (permalink) Old 10-07-2008, 01:25 AM
ProWrench's Avatar
Lightbulb
Checking for a lean condition is a great start as previously mentioned, but even if you have the ideal 14.7/1 ratio the head pipe will be glowing in the night time after a spirited ride. I have read about others with problems regarding cracked stock head pipes.
I know you said the head pipe was stock, but what about the muffler? I imagine it's stock as well due to your sound level comment. Do you have a bumper installed? I had a problem where the bumper mount would hit the muffler when the bed was tilted.
Just an idea, if you have a bumper and the bed still tilts it's something to check out.
I think that their flight from and hatred of technology is self-defeating. The Buddha rests quite as comfortably in the circuits of a digital computer or the gears of a cycle transmission as he does at the top of a mountain or in the petals of a flower. To think otherwise is to demean the Buddha--which is to demean oneself.
Robert M. Pursig
ProWrench is offline
post #8 of 11 (permalink) Old 12-03-2008, 05:54 PM
Angry Please Help
I have four Rhino 660's and have broken every header I've placed on them. I've replaced them with SS headers, DG full exhaust, new high flow fuel pump, re-jetted and still break everything....Please help
bowkill is offline
post #9 of 11 (permalink) Old 12-03-2008, 06:15 PM
First I would look at the system loose on the rhino. If the header and silencer binds up after you tighten the bolts thats a problem. If nothing is in a bind you either have a lean condition gettin the exhaust too hot and tempering the metal OR you have a junk system. It is also possible that you have a bad motor mount causing excessive movement.
post #10 of 11 (permalink) Old 12-13-2008, 01:00 PM
You need slip joint /spring in at least 2 locations to allow for heat expansion / vibration
poflo is offline
08 700 Digital Dash Problems CH366 Yamaha Rhino Electrical Discussions 2 10-13-2009 06:44 PM
Problems!!Backfiring, Sputtering, Loss of power and heat... nooch13 Yamaha Rhino General Discussions 18 10-02-2008 08:07 AM
Rotax Header QwkRhino Yamaha Rhino Engine Swap Discussions 36 10-01-2008 07:41 PM
My Intake problems Have been solved! vwgti16vt Yamaha Rhino Engine Swap Discussions 5 09-16-2008 01:23 PM
Stock Header stockgt Want Ads 4 09-10-2008 02:13 PM
