'07 Rhino 660 engine dying - Yamaha Rhino Forums - Yamaha UTV Forum
post #1 of 4 (permalink) Old 10-13-2008, 09:18 AM Thread Starter
Our Rhino is used for GPS soil testing in farm fields, it runs across the fields & stops to take samples. After the unit runs for awhile its dies, it seems to be when the air temperature is warm/hot. I have install new spark plug, clean air intake tract, clean the carb, & replaced the fuel filter. Then it ran for 7 hours with no problem. Then it started dying again, it does idle rough & when it runs it runs like new. Last year I put header heat tape to cut down the heat around the head pipe, because the dry cornstalk leaves catch fire on the head pipe. After the head pipe was wrapped with this tape it ran fine. It has been warm around here & it has ran fine for 2 weeks now it is acting up. I ran the rhino around the field for 1/2 hour then stopped & let it idle for 3 minutes then it would die. It never sputters it just dies from an idle, I can start it right back up. If I choke it, it starts right back up also, maybe a little easier then without it. I let the unit cool off for 3 hours & the air temperature drop down to 70 degrees, so then I drove it around for 1/2 hour then stopped & let it idle for ten minutes then it would die. I can start it back up & let run for a little bit then it will die again. Any ideas?
Thanks, Steve
RHINOSTEVE is offline
post #2 of 4 (permalink) Old 10-13-2008, 10:03 AM
some minor things to look for
check fuel filter often, It may take a few change's to get rid of the gunk that comes from the tank when it's new.Look for small white pieces floating in the filter.
another thing is when you put the cover back on the engine, there is a fitting at the back on the passenger side, it is a t fiiting and must be facing up or it will suck gas from the carb.
one other thing is, they come lean from the factory, Did you rejet after adding aftermarket intake???
it probably needs bigger jets.
post #3 of 4 (permalink) Old 10-13-2008, 10:15 AM
sandnuriz's Avatar
sounds like fuel filter change it out its cheep
sandnuriz is offline
post #4 of 4 (permalink) Old 10-15-2008, 11:11 AM
Also if it keeps doing it, you have to clean out the jets in the carb.
Engine Cover SXSCustms Want Ads 2 09-23-2008 01:51 PM
WTB: stock engine cover for 06 rhino VteGSR95 Want Ads 1 08-06-2008 10:53 AM
Stuck without an engine, help! PlanB43M Yamaha Rhino Performance Discussions 18 07-12-2008 07:26 PM
engine builds mx4life48 Yamaha Rhino Performance Discussions 24 06-30-2008 10:08 PM
Rhino engine carnage - Ouch! s2k1 Yamaha Rhino Performance Discussions 19 06-23-2008 12:46 AM
