Backfire at shutdown - Yamaha Rhino Forums - Yamaha UTV Forum
post #1 of 6 (permalink) Old 10-29-2008, 05:17 PM Thread Starter
loco's Avatar
Question Backfire at shutdown
Noticed that I have a small backfire sometimes like a second after the engine turns off. Sound like that valves need adjusting?
2006 Turbo Rhintax. Magnum offroad longtravel kit, Prp seats, full homemade cage with 4 7" Kragen HID's on the lightbar.
loco is offline
post #2 of 6 (permalink) Old 10-29-2008, 05:36 PM
More likely your exhaust. Birefires can be caused by sucking up air from the pipes during decelleration. Check where the two pipes connect, see if you feel exhaust coming from there. If so, you need to replace the gasket that sits inside the pipe that comes off the header. Second place to check would be where the exhaust actually connects to the headers. Check tightness of bolts, and if you feel excess exhaust there, possible replacement of those gaskets. Just did mine, and it was the connector gasket. Also replaced the bracket that holds the two pipes together, as I had lost one of the bolts. While you are in there, check tightness of all bolts that connect the muffler to frame. They can loosen, which increases vibration, which increases wear and tear.
My two cents.
skyjammer0 is offline
post #3 of 6 (permalink) Old 10-29-2008, 05:43 PM Thread Starter
loco's Avatar
Might make sence. I have a gibson exhaust.
loco is offline
post #4 of 6 (permalink) Old 10-29-2008, 08:39 PM
Unleashed UTV's Avatar
Possibly Lean
They will do that when they are lean also.
Unleashed UTV
5838 N. 19th Ave
Phoenix, AZ 85015
602-246-4011
www.unleashedutv.com
Unleashed UTV is offline
post #5 of 6 (permalink) Old 10-29-2008, 08:49 PM Thread Starter
loco's Avatar
Hmmmm, that might be the case since the only jetting I did for my rhino was when I put the cone style K&N kit I put the bigger jet it came with. I have not compensated for the new exhaust.
loco is offline
post #6 of 6 (permalink) Old 10-29-2008, 08:52 PM
Yes
Probably need a bigger pilot jet and maybe bump the needle up a little and change the idle screw setting.
Unleashed UTV
5838 N. 19th Ave
Phoenix, AZ 85015
602-246-4011
