radiator fluid loss - Yamaha Rhino Forums - Yamaha UTV Forum
post #1 of 12 (permalink) Old 11-30-2008, 11:16 PM Thread Starter
radiator fluid loss
OK, I came back from a day trip. I notice something had leaked on the trailer floor. It was anti freeze. After inspection it appeared that the fluid came from a small clear hose on the water pump (poss overflow). I didnt notice it leaking while i was driving it. but seemed to leak while it was not running and on the trailer. any ideas what caused this.
Bigcitymc is offline
post #2 of 12 (permalink) Old 12-01-2008, 07:20 AM
Sounds like a leaking water pump seal to me. Probably not leaking enough to notice while driving, but leaking none the less.
Lil Foot is offline
post #3 of 12 (permalink) Old 12-02-2008, 06:55 PM Thread Starter
would a leaking water pump sea; leak out the clear hose..???
post #4 of 12 (permalink) Old 12-02-2008, 07:21 PM
I would guess the same......That should be an easy enough fix.......tell your "BYC rhino wrencher" he has work to do......
post #5 of 12 (permalink) Old 12-02-2008, 07:39 PM Thread Starter
I take it the seal is inside the housing....now that is on the under side of the engine...how hard is it to open that up..
post #6 of 12 (permalink) Old 12-02-2008, 07:52 PM
I think the hardest party will pulling out the tank........It only has a couple of small bolts. But I think the tank is in the way.
post #7 of 12 (permalink) Old 12-02-2008, 08:15 PM Thread Starter
thanks... i was just looking at it and the gas tank might be in the way.. im hoping that if i take iff that fan i can squeez in there... Ill get those parts on order and give it a whirle... ill get back on and let you guys know how big of a pain it was.. thanks for the help.. if anybody knows any tricks let me know..
post #8 of 12 (permalink) Old 12-02-2008, 08:25 PM
You need to remove the water pump from the engine to do this job. It can be done, but it is tight quarters.
The fuel tank does NOT need to be removed, although access and visibility would be better with it gone.
The water pump has two seals. I have never had much luck getting them out of the Rhino water pump without wrecking them. I would replace both seals and be done with it.
You will need to drain the oil in the engine. When the water pump is removed, it is below the oil level and oil will pour out the side of the engine.
When you reinstall the water pump, you'll need to line the end of the impeller shaft up with the corresponding drive on the end of the oil pump shaft.
Get er done!
Benchmark Performance
760-484-0986
s2k1 is offline
post #9 of 12 (permalink) Old 12-05-2008, 01:34 AM Thread Starter
thanks guys for all the help.... I got it out and had to take it to the local dealer to remove and install the seals as you need a "special tool"... it cost a few bucks but it's done. im looking foreward to getting it started and making sure its done right.. thanks again.
post #10 of 12 (permalink) Old 01-10-2009, 04:17 PM
Rhino Water Pump
I'm having the same problem and removed the bolts that hold the water pump on but on the front part came off. Do i need to force the back off? Do you have to take the side of the motor completely off, or just the water pump?
Thanks,
JG
jgraham37128 is offline
radiator ronobanshee Yamaha Rhino's & Rhino Parts For Sale 1 11-03-2008 02:29 PM
Problems!!Backfiring, Sputtering, Loss of power and heat... nooch13 Yamaha Rhino General Discussions 18 10-02-2008 07:07 AM
PWR Radiator Teebone56 Yamaha Rhino General Discussions 11 08-20-2008 03:56 PM
2006 Radiator and 2007 Radiator ??SAME?? stetler Yamaha Rhino General Discussions 4 07-23-2008 10:10 AM
C&R Rhino radiator HRT Motorsports Yamaha Rhino General Discussions 0 07-16-2008 11:42 PM
