Only idles - Yamaha Rhino Forums - Yamaha UTV Forum
post #1 of 5 (permalink) Old 09-22-2018, 07:57 AM Thread Starter
Hi, newby here. Just bought an '07 Rhino 660 used and was running fine for short time, then stalled. Now only starts with choke pulled out, but stalls when you try to accelerate. Any ideas? Is it running lean and by pulling choke I get right air/ fuel mix? Thx in advance. Mark
Ripp6957 is offline
post #2 of 5 (permalink) Old 09-23-2018, 06:38 PM
do you let it warm up 3 or 4 minutes. if yes then i would check your fuel pump and replace it with the high volume one.
woodwardsh3 is offline
post #3 of 5 (permalink) Old 09-23-2018, 10:25 PM
LBR
Administrator
LBR's Avatar
Sound like possibly old gas since you just bought it...had it sat a few months maybe? If so....
Drain or siphon as much out of tank as possible, replenish with a couple gallons of FRESH gasoline, then start and nurse it with the choke for awhile and see if it starts responding better.....if so....
Add a good amount of Seafoam to your new gas and drive. It will start cleaning carb up. May take awhile of the gas/Seafoam mixture, but small engines usually respond great to this "medical treatment."
LBR is offline
post #4 of 5 (permalink) Old 09-25-2018, 05:31 AM Thread Starter
Thx for your ideas. Yes, it probably has been sitting for a while. I did not add any fuel, as I wanted to run the old stuff out first. Ill drain the tank and try the Sea Foam.
Ripp6957 is offline
post #5 of 5 (permalink) Old 10-10-2018, 07:05 AM Thread Starter
Update (late) I figured out the fuel pump was bad. Replaced and working well. I went ahead and drained old fuel first and added Sea Foam to new fuel. The fuel pump was $12 on Amazon! I'm sure liking the affordable replacement parts for this model! Thx again for y'alls help.
Ripp6957 is offline
