oil leak - Yamaha Rhino Forums - Yamaha UTV Forum
 1Likes
post #1 of 12 (permalink) Old 11-15-2018, 01:32 PM Thread Starter
Question oil leak
I have 2008 and it is leaking oil out of the bottom of the stater cover. Pulled it off and changed gasket, but it still leaks. Torque for cover bolts said it was 7.2 ft/lbs. Can I go tighter or is there something else I should do?
r1patton is offline
post #2 of 12 (permalink) Old 11-15-2018, 07:03 PM
Steve Osborne's Avatar
i have a 700...so not much help other than checking for a crack in the block or side cover...bolting it up will stress/stretch/bend it open...so may not see it with it off ..
r1patton likes this.
Steve Osborne is offline
post #3 of 12 (permalink) Old 11-16-2018, 08:58 AM Thread Starter
I'm pulling it back off to check. I'll let you know.
r1patton is offline
post #4 of 12 (permalink) Old 01-11-2019, 09:05 AM Thread Starter
Everything went well. It was just a offset gasket. No more leak.
r1patton is offline
post #5 of 12 (permalink) Old 01-24-2019, 12:37 PM Thread Starter
My 08 Rhino 700 only goes 25 mph in high. Is that it? At 25 it sounds like it is at a pretty high rpm. Speed is okay for around the lake, but I was going to use it to drive from my shop to the house. It is about 1.25 miles on 45 mph road.
Any ideas for more speed?
r1patton is offline
post #6 of 12 (permalink) Old 01-24-2019, 03:24 PM
my 2011 700 tops out at 60kmph...approx 37mph....be interest to see what can be done... maybe clutch adjusting/weight changes?...
post #7 of 12 (permalink) Old 01-25-2019, 06:25 AM Thread Starter
I've got it half throttle at 25 mph. That's all it will do. Doesn't make any difference on pushing down the rest of the way. Actually seems like it just needs to go to another gear. The previous owner rolled it over and I reset the code. Didn't make any difference.
Could there be an exhaust issue? Maybe like too much back pressure?
r1patton is offline
post #8 of 12 (permalink) Old 01-25-2019, 03:39 PM
yes for sure on the exhaust....spark arrester in the muffler tip...mine the previous owner mudded with it it was 95% plugged.. had approx 1/2 hole of the mesh left open...used a can of Yamaha combustion chamber cleaner and let it soak and brush and soak and brush the carbon and mud off it....think one of my other posts may have a pic..yep..got it...
post #9 of 12 (permalink) Old 01-30-2019, 09:58 PM Thread Starter
Exhaust is clear. Going to check belt and clutch next. Where's a good place to buy the clutch parts?
r1patton is offline
post #10 of 12 (permalink) Old 02-07-2019, 04:17 PM Thread Starter
Needed belt but didn't help. I think it is a programmable issue.
r1patton is offline
