'06 -660 choke adjustment - Yamaha Rhino Forums - Yamaha UTV Forum
post #1 of 3 (permalink) Old 01-02-2019, 10:27 AM Thread Starter
Mills's Avatar
I have an '06 660 special edition, every time I use the choke it opens by itself as the unit is running. it is very loose at the carburetor end, enough so that I can pull the metal tube out of the carburetor that the choke cable goes through. If I adjust it at the carb so that the tube does not pull out and the cable is just barely taught, I have very little extension of the choke handle on the dash. is this common? is the cable frayed inside the jacketing? Should I replace the cable? Any suggestions would be much appreciated.
Mills
Mills
Mills is offline
post #2 of 3 (permalink) Old 01-05-2019, 06:16 AM
Steve Osborne's Avatar
from what I see and read...I couldn't find any form of adjustment... and the description you give ..it sounds like the cable is damaged/jammed inside the casing...
free manual ..
https://www.manualslib.com/manual/66...60.html#manual
Steve Osborne is offline
post #3 of 3 (permalink) Old 11-15-2019, 05:29 AM
I’m not super knowledgeable on carbs and this had things going right away. I owe this man a beer!
Grefio is offline
