Dry Fuel Filter - WTF? - Yamaha Rhino Forums - Yamaha UTV Forum
post #1 of 9 (permalink) Old 08-23-2009, 01:45 AM Thread Starter
pronstar's Avatar
Rhino won't start.
Fuel filter looked dirty so I cleaned it...but it was also dry.
Put new filter on. Turn the engine over, the new filter isn't drawing any fuel.
For shits and giggles, I could easily suck fuel up through the fuel filter ,so there's no clog.
Checked the plug - definitly got spark.
Definitely got vacuum coming off the intake tract.
Took the fuel pump off, pretty simple device.
What could possibly go wrong?
At any rate, I assume I need a fuel pump.
How do these things fail? Seems like such a simple device...?
'07 Rhino 660 * Mason LT * Elka Elites * Ron Woods exhaust * 38.2 hp on the Pro Shop's Dyno * LiveWire Whip
pronstar is offline
post #2 of 9 (permalink) Old 08-23-2009, 02:09 AM
warlock's Avatar
those fail all the time atleast your at home not on the trail.
warlock is offline
post #3 of 9 (permalink) Old 08-23-2009, 09:30 AM
Pr3m1um M3mb3r
predu's Avatar
why don't you put the one you have for sale on it ?
I'm stayin neutral here, but you DID report kyle's post to admins.
that might work at rf, but not here, not even if johnny asked me to remove
kyle's post would I do it.that is on principal alone.
predu is offline
post #4 of 9 (permalink) Old 08-23-2009, 09:52 AM
yeah you posted the fuel pump for sale 2 mins after you said you need one?
Hounslow is offline
post #5 of 9 (permalink) Old 08-23-2009, 12:07 PM Thread Starter
pronstar's Avatar
It has an extra tube on it an I have no idea what plugs into it...and the mounting holes are different.
My tune is for a stock pump (not sure if it matters), if I could just trade straight across/break even for a stocker it would be easier.
I have to get this put on today and don't have a lot of time to muck with it.
pronstar is offline
post #6 of 9 (permalink) Old 08-23-2009, 12:29 PM
ryanPSD's Avatar
It has two outlets, you simply block off the second outlet. The mounting is slightly different and I have only one bolt holding mine in at the top, if I remember right, and it works like a champ. I don't think it would make a difference, as far as the way your motor is tuned... ?
TOAST NO MORE
Longest downtime record has been set!
ryanPSD is offline
post #7 of 9 (permalink) Old 08-23-2009, 08:13 PM
jws
jws's Avatar
Rob - You just lost your prime no worries. Ive had the same thing happen after letting mine sit for a while also. I do have an extra stocker if you need it...
jws is offline
post #8 of 9 (permalink) Old 09-04-2009, 01:31 AM
Benzito's Avatar
Originally Posted by pronstar View Post
Rhino won't start.
u can blow into the 1 line that goes into the frame u take of breather or just start it with starting fluid it will fire right up and will prime the system ..
they say a rag stuffed in the intake side of carb will work but we tried it and it didnt work or it took forever just use a lil gas or starting fluid and start it and it with that and it will prime itself and fill up and u will be good to go ...
the full pump u have is 100% perfect , u will only use 1 bolt hole to mount it
and u will cap one end off or run both lines to a T then 1 line to carb ...
http://www.unleashedutv.com/
http://traillogicllc.com/
Benzito is offline
post #9 of 9 (permalink) Old 09-09-2009, 09:10 PM Thread Starter
pronstar's Avatar
Tried blowing thru it...20 psi of air thru it...putting gas in it to prime it...nothing revived the dead pump. Nothing would flow thru it.
pronstar is offline
