Problem with new Rhino!!! - Yamaha Rhino Forums - Yamaha UTV Forum
post #1 of 9 (permalink) Old 09-15-2009, 10:50 PM Thread Starter
We just brought home an '07 660 with 88 hours on it. It hasn't been rode much in past few months. When ever you put it in High and take off the Reverse light comes on almost imediately. When you get up to around 22 or 24 MPH it starts cutting out. We changed the fuel filter, cleaned the air filter, and changed the Plug and it still does it. Any Ideas on what is going on?
Hunt79 is offline
post #2 of 9 (permalink) Old 09-15-2009, 11:54 PM
Yes, i'll tell you exactly what is going on.
There reverse switch wire is making a poor connection to the reverse switch. The reverse switch is located on the top of the engine cases, directly underneath the airbox. The airbox may even be rubbing the connector on the switch.
To confirm, remove the wire from the switch. It is green with a white tracer. Connect the wire to ground (engine cases are fine) temporarily and test drive it. If the problem is gone, you have found the source of your frustration.
Your choices are:
1. Squeeze the connector and make i fit the switch tighter.
2. Leave the wire grounded all the time. NOTE - this will disable both the reverse light and the reverse rev limiter. It will now go any speed in reverse. Use caution when in reverse if choosing this route.
Benchmark Performance
760-484-0986
s2k1 is offline
post #3 of 9 (permalink) Old 09-16-2009, 06:45 AM Thread Starter
Thank you!!!!! I'm heading out to the shop to try that out. I'll let you know the outcome.
Hunt79 is offline
post #4 of 9 (permalink) Old 09-16-2009, 07:17 AM Thread Starter
Thanks a million!!! that fixed it. Couldn't see it was loose though. I just took the plastic clip off and squeezed it tighter put it back on switch with out plastic cover and good as new.
Hunt79 is offline
post #5 of 9 (permalink) Old 09-16-2009, 09:51 AM
that'll be about two fity thank you come again.
post #6 of 9 (permalink) Old 09-17-2009, 10:31 AM
From what you stated that fixed the problem, leads me to believe that it probably just loosens up after time from vibrations, then if it gets loose enough dust will enter the cover and start causing issues with the contacts.
Good, cheap easy fix though, that's always a good thing.
wildbill23c is offline
post #7 of 9 (permalink) Old 09-27-2009, 09:43 PM
check for trash in your fuel jet
hunterdeer76 is offline
post #8 of 9 (permalink) Old 09-29-2009, 09:58 AM
broccoli2's Avatar
Your first post and you don't read any of the posts that came before you. WTF. Thanks for stoping by
broccoli2 is offline
post #9 of 9 (permalink) Old 09-29-2009, 02:01 PM
ljb
good shit right there
08 700 SE
XMF LT
HID's
Livewire whip
and some quads and a KTM
ljb is offline
