Okay guys, I'm heading to Pismo on the 25th-28th with the trailer in tow for the first time. I have been hearing horror stories so far. Hers what I have been told.. If I get there on Friday I'm F'd because all the beach front spots will be taken and if the tides up I won't be able to get by them to get to a spot to set up camp so be sure to get there at like 9AM! Secondly is to cover everthing under my truck and trailer with WD40 so when the weekends done I won't have rust issues and I can just go and wash everything off. 3rd thing is to bring plenty of ply wood ripped down to about 3ft widths and go around the whole back side of my trailer if I am where the tide rolls in because the winds pick up at night and blow underneath the trailer and make life miserable and it also helps keep the tide from going under the trailer (sounds like the tide comes in pretty high). Also, air down the truck and trailer to about 17 lbs. Is it really that hard to get a spot to camp at on a Friday? I have reservations made but I am told that its already filled in by then.
It is pretty hard to get a spot by the water on a weekend.
I air down to 12 - 15 psi.... that is it. I dont mess with WD40, plywood or anything else. Keep everything locked up because there are a few local petty thieves. They like tools and gas cans.
all good advice no on wd40 but when you get home park over a sprinkler for an 1/2hr. that will wash under the rig the best AIR DOWN right when you pull onto the beach and yes we take ply wood to put around our traler but it has not been windy so you should be ok and yes beach frount fills up fast
Depending on how big your trailer is. I have had to go as low as 10lbs in the summer I am running bfg ats e rated so the sidewalls don't bulge much. In winter I only go down to about 20. make sure to air the trailer down and take a square nose shovel
trailer any trailer should go to 15psi truck pull behind 15psi all the way around 5th wheel 20psi rear 15 front and you can go any where:good:wave as you go by buelton (pee soup)
Hay look ryan is at 1/2 Throttle not much longer and you can make 3/4
Throttle :laugh::laugh: and yes pee soup cant miss our billbourds they start in l.a.
I found this setup which I think would be a great add on to a toy hauler if you go to Pismo often... what do you all think? I was thinking you can plug the hose from the trailers pressure washer to it and it would allow you to clean the chassis at your storage facility. 4wd Accessories Australia
Related Threads
118.2K posts
8.5K members
Since 2008
