Running rough - Yamaha Rhino Forums - Yamaha UTV Forum
post #1 of 4 (permalink) Old 11-26-2009, 12:20 PM Thread Starter
Running rough
I have searched all three Great Sites trying to solve this issue. My Rhino will not idle. It actually sounds like a two cylinder engine running on one. It sometimes burps (not backfire) through the carb. When the engine stops it stops hard. Using my search research I have done the following and checked the operation after each change.
*Drained the fuel and refilled with Shell Techron Hi Test and a bottle of Techron fuel additive.
*Changed the fuel filter
*Cleaned the intake filter (even tried running it with the intake filter)
*Checked the plug
*Adjusted the intake valves (as did most other people I found them to be tight)
*Cleaned the Pilot Jet
*Replaced the fuel pump.
bjpoppie is offline
post #2 of 4 (permalink) Old 12-04-2009, 05:44 PM
Mayby a vacuum leak at your intake pipe
yamadodge is offline
post #3 of 4 (permalink) Old 12-05-2009, 10:02 AM
have you adjusted the mix screw?
timing chain could be loose also.
like said, the intake boots a prone to cracking.
post #4 of 4 (permalink) Old 12-05-2009, 10:17 AM
I agree, a hole or crack in the intake boot or a exhaust leak, if not, then it's a timing problem.
