No torque when acclerating - Yamaha Rhino Forums - Yamaha UTV Forum
post #1 of 12 (permalink) Old 12-04-2009, 06:25 PM Thread Starter
I have a 2004 rhino with cdi, a larger jet, and 27 inch tires. When accelerating it feels like its starting in third gear and after a few seconds it "downshifts" and has power again, however if starting on an up hill it will continue to bog down because it has not reached whatever speed it wants to "downshift" at (yes i do realize the rhino has a CVT transmission and does not have "gears"). Originally i thought that the v belt was slipping, but upon inspection i found that the belt was in good shaped, the sheaves were clean and smooth and it was within spec. I replaced the belt anyway and still have the same problem. Any thoughts?
hondadude60 is offline
post #2 of 12 (permalink) Old 12-04-2009, 07:04 PM
goodguys75's Avatar
welcome to the site. 1st question is it a 450 or 660.....and bigger tires are killer on these machines....
JUST SAY NO TO C**K SNAPPING
IM RICK JAMES BIOTCH!!!!!
http://www.dumontduneriders.com/imag...ers/468x60.jpg
goodguys75 is offline
post #3 of 12 (permalink) Old 12-05-2009, 09:54 AM
you need to put a clutch kit in it.
start with a stiffer secondary spring, this will keep it in a "lower" gear longer.
post #4 of 12 (permalink) Old 12-05-2009, 05:07 PM
Thumbs up no power or torque
Like one coment said you have too look closely at your wet clutch if you did check other stuff.First of all,is the oil getting dirty fast 'black;,and have a bad smell.Also did you take appart the primary clutch before changing your belt they are not easy to mix up like the sliding wheights,it happened to me last time I took it appart to clean! Anyway I hope this helped you!
YAMADODGE:
yamadodge is offline
post #5 of 12 (permalink) Old 01-03-2010, 09:29 AM
Clutch issue?
Mine is having the same problem. Was told to clean, re grease and inspect the weights. So I replaced the weights and regrease and replaced the belt. Everything else looked good. It did not fix the problem. I noticed that this has been getting worse over the last year but really screwed it up last weekend riding.Stuck in high in a bad spot and had no choice but to creep up hill in high. Knew it would screw it up. Something is wrong. Runs good after the intial takeoff. If it had gears seems like its taking off in 3rd gear. Could this be the main clutch in the powerterrain in front of primary clutch.
RPKUHL is offline
post #6 of 12 (permalink) Old 01-03-2010, 09:46 AM
remove the cvt cover...start the engine in neutral....rev the engine up and back to idle and watch the belt move up and down in the pulleys to make sure the belt is traveling all the way up and down in the pulleys... if its not there is something wrong in the sheave or the secondary pulley........
rhinodad is offline
post #7 of 12 (permalink) Old 01-03-2010, 11:02 AM
I opened it up this morning and did just what you said and it seems to work ok. Not sure at what rpm it should start to open up up but it does. Could there be a problem with the secondary spring? When put it in drive and start to accelerate it moves slow but the more you accerate you don't really feel it engage until you get it moving just like starting in a high gear. Or like a car with a badly worn clutch. Could it be the main clutch behind the primary sheave in the driveterrain?
RPKUHL is offline
post #8 of 12 (permalink) Old 01-03-2010, 11:05 AM
This all happened driving in high when it should be in low. Seems like a burnt clutch
RPKUHL is offline
post #9 of 12 (permalink) Old 01-03-2010, 01:02 PM
do you hear the rpms go way up when you accelerate??? if the wet clutch was bad it should be slipping......
rhinodad is offline
post #10 of 12 (permalink) Old 01-03-2010, 01:09 PM
Yes the rpm went up. Is the wet clutch the part on the in side? Everything looked good and sounded good when I did your test. I wondering if the spring is bad?
RPKUHL is offline
accleration, sluggish, torque
