06 660 Rhino
While Rhino is in neutral with the cover off the sheave you can rev it up and let off the gas and the pulleys keep spinning for a long time while making a grumbling noise. Finally when everything quits spinning the noise stops. Belt looks good and is not slipping. What the hell? also the engine brake dosent work anymore
