Rhino 660 working poorly after engine rebuild - Yamaha Rhino Forums - Yamaha UTV Forum
post #1 of 7 (permalink) Old 05-09-2010, 03:41 PM Thread Starter
Put 100.5 mm piston in rhino after i ran dry of oil. Has not worked good since., Will not idle properly, engine brake not working, will not bring idle down after full throttle. seems to be low on power. any help would really be appreciated
wideopenwade is offline
post #2 of 7 (permalink) Old 05-09-2010, 04:27 PM
cam is off timing, or decomp pin assembly is open. pull the rocker cover and check. could have set timing chain on wrong mark
post #3 of 7 (permalink) Old 05-09-2010, 05:53 PM Thread Starter
Can you give me a few instructions about what to look for in any of these ideas.
post #4 of 7 (permalink) Old 05-09-2010, 07:58 PM
JoeyD23's Avatar
JoeyD23 is offline
post #5 of 7 (permalink) Old 05-10-2010, 03:24 AM Thread Starter
Im in Nova scotia Canada
post #6 of 7 (permalink) Old 05-10-2010, 09:12 AM
MRPAT920's Avatar
heres what the de-comp pins assembely look like
MRPAT920 is offline
post #7 of 7 (permalink) Old 11-13-2012, 11:03 AM
3 strikes and I'm out of ideas. I have replaced the center intake valave on my Rhino motor 3 times now. The center valve eventually makes contact with the piston and break the valve stem off OR the valve. The Valave and guides are always new and done at a machine shop. Piston and rings are new, New timing chain, New upgraded chain tensioner. Runs great around the nieghborhood. Then when I take out to ridding area the vakve breaks within 10 minutes. The timing has been checked, rechecked and triple checked. I'm at a loss. Was wondering if the pin inside the cam that contact the center valve might be the problem, and Ideas anyone ?
atvhigh is offline
