Rhino wont change gears! - Yamaha Rhino Forums - Yamaha UTV Forum
post #1 of 9 (permalink) Old 06-25-2010, 07:30 PM Thread Starter
Hi I,m new to this site so I hope I'm posting in the correct place, but anyway here it goes. I have a 2005 rhino 660 and for some reason I cant change gears while its running but if I shut the engine down it will change just fine. Any Ideas would be greatly appreciated
rhinosized is offline
post #2 of 9 (permalink) Old 06-25-2010, 10:26 PM
two things your idle may be too high and there is a link that loosens over time you can follow the shifter to the tranny and look for the turnbuckle loosen or tighten till it works right.
spooledup24v is offline
post #3 of 9 (permalink) Old 06-26-2010, 07:11 AM
Bryan M's Avatar
sounds like idle...theres a lil screw on top of the carb you can adjust by hand try that...
Bryan M is offline
post #4 of 9 (permalink) Old 06-26-2010, 10:11 AM
sounds like the idle is too high
john m is offline
post #5 of 9 (permalink) Old 06-26-2010, 10:15 AM
sounds like idle is too high
john m is offline
post #6 of 9 (permalink) Old 06-26-2010, 12:37 PM Thread Starter
Thanks guys I'll try and see if it works. By the way I had to clean some mud out of the belt drive yesterday so I completely disasemble the outer drive and cleaned it and regreased it. I then reinstalled it and tightened the outer nut back to the original 60# of torque I wouldnt think it would have anything to do with the shifting though or does it?
post #7 of 9 (permalink) Old 06-30-2010, 03:40 PM
no, if it is wrong it would still go into gear, just not take off or upshift properly.
try to shift it, with motor off, then start to see if it is in the gear your selected.
it will start in any gear, with foot on brake.
post #8 of 9 (permalink) Old 06-30-2010, 07:36 PM Thread Starter
Talking
I adjusted the idle as suggested and it seems to have fixed the problem. I never dreamed just because the idles a little high it would stop it from going in gear. Thanks so much for ya'lls help.
post #9 of 9 (permalink) Old 07-01-2010, 09:43 AM
the reason it does this, is due to the one way bearing and wet clutch engaging and moving the secondary clutch so it will not go into gear when the secondary is moving. FYI
nee help for my rhino
