cooling fan trouble - Yamaha Rhino Forums - Yamaha UTV Forum
post #1 of 4 (permalink) Old 09-02-2010, 10:10 AM Thread Starter
cooling fan trouble
I have my cooling fans wired in direct. They always start up when i turn the ignition on. When were out riding for awhile i notice they will cut in and out like from factory. This is a problem while riding slow trails and its 100 degrees outside. My question is do the fans have a internal shut down switch or is the factory relay breaking down. The fans seem to never shut off while idling only when riding.
jonboy84 is offline
post #2 of 4 (permalink) Old 09-06-2010, 12:58 PM
sandflinger's Avatar
Wire the cooling fan thru a relay and a manual switch instead. Your fan is cutting out due to a bad relay or power connection. If you continue running that way, you may end up frying the fan and they aren't cheap to replace. If you wire the fan (over ride switch) it's in-expensive. I did mine for under $20. Wiring it thru a switch...with the switch "off" it will turn on at the factory setting. If your switch is "on" the fan will stay on all the time even when the motor is off.Here in Az. where temps get over 110...this really keeps temps down.
If you have two fans...you should wire them through two relays and even two switches unless you can find a switch that can handle the current draw of BOTH fans in series.
sandflinger is offline
post #3 of 4 (permalink) Old 09-08-2010, 01:47 PM Thread Starter
Will do thanks for input.
jonboy84 is offline
post #4 of 4 (permalink) Old 09-08-2010, 02:02 PM
No problem,glad I could help
