shifting problems - Yamaha Rhino Forums - Yamaha UTV Forum
post #1 of 7 (permalink) Old 01-10-2011, 09:11 PM Thread Starter
shifting problems
I have a stock '07 rhino 660. shifting into neutral and low has become very frustrating. I have to push it twice for it to go into low. And trying to find neutral is hard.
hummdeere is offline
post #2 of 7 (permalink) Old 01-05-2012, 04:46 PM
Did you ever get an answer on this? I have the same issue and was looking for help.
Thanks!!!
Tony
Acehardly is offline
post #3 of 7 (permalink) Old 01-06-2012, 11:36 AM Thread Starter
Thanks!!!
Tony
I sure haven't. It's really frustrating though. Now it takes forever to start when it has been sitting for several days, it's like it isn't getting gas and i changed the fuel pump.
post #4 of 7 (permalink) Old 01-07-2012, 03:49 PM
Sneaky snake's Avatar
You may have to adjust your linkage rod from shifter to your transmition
Sneaky snake is offline
post #5 of 7 (permalink) Old 01-09-2012, 09:17 AM
or check that the bolt holding the arm onto the motor is tight, mine came loose, I used Blue locktite and never came loose again.
also check your idle speed, if it is too high, it will cause shifting problems while running.
for starting issues, check all vacuum lines to pump, check the "enrichener" connection at the carb, and clean inside also where the pin goes in.
post #6 of 7 (permalink) Old 10-04-2012, 10:33 PM
regarding starting problems
i own a 2007 660 rhino and have always had an issue starting if she has sat for a while. Our local yamaha mechanic up here told me to grab hold of the roll cage and shake her violently. He claimes the needle tolerance is to tight.It works but there must be a better solution.
BP
Cold Lake
Alberta
wlvb is offline
post #7 of 7 (permalink) Old 11-18-2012, 08:13 AM
I agree with the idle being too high, when I had problems shifting it was because my idle was too high. I lowered it and it's been smooth as butter ever since.
Vital is offline
