Help ! Rhino wont stay on - Yamaha Rhino Forums - Yamaha UTV Forum
post #1 of 4 (permalink) Old 01-15-2011, 07:27 PM Thread Starter
Trooper522's Avatar
Ok guys I need some help. the rhino has been sitting for awhile so I went to go and start it today and it starts with the choke on but but after I let go of the choke it dies. So I went ahead and cleaned the air filter, changed the oil and oil filter, since it was a while since I last changed it. I also put some fresh gas in it and I still have the same problem.
When I let go of the choke I try to keep it going with the gas pedal and it revs up and back fires a little bit.....is this a carb issue ? Please help !!
Trooper522 is offline
post #2 of 4 (permalink) Old 01-16-2011, 08:59 AM
warlock's Avatar
Yeah your carb is plugged up with some varnish. When ever you let gas powered stuff sit for to long now days the shitty fuel starts to varnish up and when it does it plugs carbs up. Same with the generators on toyhaulers they recomend starting and running for ten or so minutes monthly..
warlock is offline
post #3 of 4 (permalink) Old 01-16-2011, 01:26 PM Thread Starter
Trooper522's Avatar
Thanks Warlock...I was kinda thinking that. I got the carb out but still hanging by the throttle cable which Im thinking Im going to leave on. I can get to the float bowl but those screws are a son of a bitch to remove. Once I got the float bowl off I should be able to get to the jets ? right ?
post #4 of 4 (permalink) Old 01-16-2011, 06:28 PM Thread Starter
Trooper522's Avatar
Yep it was the carb...small jet plugged up...had to drill out those stupid screws and replaced with alan head metrics purrs like a kitten now
