07 660 oil leak question. - Yamaha Rhino Forums - Yamaha UTV Forum
post #1 of 7 (permalink) Old 02-20-2011, 12:14 PM Thread Starter
Have an 07 660 that recently had a new piston and rings installed by previous owner and he experienced a fairly severe oil leak. I bought it from him and quickly found the source of the leak. There was a little clear hose (1/8th inch) that was laying on the skid plate right under the engine. I used a zip tie and tied it up vertical so it would not leak. I assumed this was some sort of breather hose for the crank. After running it for about 200 miles everything was okay. This last oil change I put in a heavy 15w40 oil and now it pushes a little oil out and coats the passenger side of the engine. I have looked in my repair manual and it never mentions this little hose, so I ask: What is the purpose of the hose and where should it be located? Can post pictures if needed.
Thanks in advance!
kyleofthenile is offline
post #2 of 7 (permalink) Old 02-20-2011, 12:55 PM Thread Starter
The hose outlined in white is the leaking hose. I have no idea where it goes. The hose in red is the carb breather hose.
post #3 of 7 (permalink) Old 02-21-2011, 06:19 AM
onebuilder's Avatar
Kinda hard to tell. Looks like it may be the hose coming off of the bottom of the water pump. Pull the right rear tire and look at the bottom of th water pump. It may be a simple and cheap fix.
Dirt flies when your having fun!
onebuilder is offline
post #4 of 7 (permalink) Old 02-21-2011, 07:09 AM Thread Starter
Ok, I pulled the tire and then used my repair manual to confirm that the hose is the water pump breather hose. I still don't know why oil is coming out of it and where the hose is supposed to go. The diagram in the manual is not so good...
post #5 of 7 (permalink) Old 02-21-2011, 10:39 AM
onebuilder's Avatar
Ok, The vent line only attaches to the water pump, the other end lies under the engine going out back towards the right rear tire. On the 660s the water pump is driven off the oil pump. You have a seal that has gone bad between the water pump shaft and the oil pump. Easy fix, remove the water pump and replace as an assembly or just the needed seals. Look at a parts breakdown of the water pump online. Where are you located? Apache Yamaha(as do most dealers) have a great parts breadown with descent prices.
Check your radiator and cooling system for oil in it! You may have to flush the system if it has oil in it. Usually coolant leaks out of that hose when the seal goes bad.
Do you see coolant in the oil?
post #6 of 7 (permalink) Old 02-25-2011, 01:51 PM Thread Starter
Checked the coolent and didn't find oil in it. So I went ahead and pulled the water pump. Noticed that the lip on the oil seal was backwards and the little spring that helps hold the seal tight to the shaft had a small kink in it. My only guess it that it had water pump seal problems once before and somebody doesn't know the proper way shaft seals are supposed to be installed. I'll have to inform my friend on the proper way soon...
I have a new water pump coming in the mail. I didn't like how the shaft was worn where the seal rubs, and the ceramic portion didn't look to be in too good of shape and one fin on the impeller was missing... I thought it best to start from scratch!
Thanks for your help!
post #7 of 7 (permalink) Old 02-28-2011, 01:56 PM
yes start from scratch.
make sure you burp the system after filling with water/coolant.
on driver side outlet there is a small bolt for bleeding air out., fill with water start motor with bleeder open, keep filling until water comes out the top, tighten. run for a couple minutes at idle, then check rad to see if still full.
