not shifting right - Yamaha Rhino Forums - Yamaha UTV Forum
post #1 of 4 (permalink) Old 09-18-2011, 12:44 PM Thread Starter
not shifting right
hey guys new to the site. have couple questions. my 05 rhino is not wanting to go into low gear and it cuts out when diff lock is engaged. any thoughts..any help appreciated
rampage11 is offline
post #2 of 4 (permalink) Old 09-18-2011, 05:30 PM
I'm pretty new to the ATV/UTV world myself, but I've heard in the past that if the transmission is hard to get into low range, its usually due to the shift linkage binding, being bent, or not properly adjusted.
For the cutting out when diff-lock is engaged that's due to the diff-lock not being fully engaged. This could be due to a problem with the differential internals and if it happens all the time you'll probably have to take it in and have it serviced unless you know how to work on the mechanism yourself. However if its just once in a while, its pretty common sometimes that the diff-lock takes a few seconds to engage what I've found that helps is to turn the steering wheel while engaging the diff-lock mode. Once its engaged (the diff-lock light will become steady and not flashing anymore) it should be able to gain speed.
I'm not familiar with the older models but I think they had some sort of governor on them to limit full throttle acceleration when in diff-lock mode which would cause the machine to cut out at a certain speed.
wildbill23c is offline
post #3 of 4 (permalink) Old 09-18-2011, 07:34 PM Thread Starter
thanx.. it finally locked in and ran fine.. i unhooked the linkage on gear shifter and was shifting manually. i could push it all the way back and it just stopd.. like it was binding
post #4 of 4 (permalink) Old 09-29-2011, 08:32 PM Thread Starter
anyone gonna give any input? could use some help..still having trouble with low gear
