Basic fuel pump question - Yamaha Rhino Forums - Yamaha UTV Forum
post #1 of 6 (permalink) Old 04-01-2012, 04:14 AM Thread Starter
I have a 2006 660 Rino. I'm not a mechanic and only have a little practicle knowlege. Last week I was antler hunting and went down a steep incline road into a deep canyon. Say I was about 2 minutes going downhill slow using the engine to hold me back while beaking intermittenly. Lost fuel. Filter seemed to be working fine. Checked all the lines and when I examined the fuel pump noticed no electricle connections. Figured it must work off vacuum.
I jerry rigged a gravity feed system to get out and I was riding the pump began to work fine. I've had no problems since. Is there a potential problem in the future? Did my downhill ascent cause this and is there something I can do to prevent this happening? Thanks for any insight!
Barryhoff is offline
post #2 of 6 (permalink) Old 04-01-2012, 06:39 PM
I just had a similar issue, not with mine but with a friend's 2007 660. We let it sit on a down hill incline while swimming in the creek, then after 45 minutes started her up, and after the carb ran out of fuel she died. Ended up towing it back. Saw no fuel coming from fuel pump, took it apart at camp, saw nothing wrong, looked great, fuel in filter, fuel flowing easy from tank. Put it all back together and feed her a little direct fuel to get it running, and the fuel pump started working again, seemed fine the rest of the weekend? Seems like the incline wasn't good???
jdshort98 is offline
post #3 of 6 (permalink) Old 04-01-2012, 09:51 PM Thread Starter
Exactly! I just want to be sure it's not fuel pump failure but something to watch for when I go out!
post #4 of 6 (permalink) Old 07-21-2013, 02:56 PM
fuel pump?
I just had the same thing happen to me. Going down hill and the motor in my '07 660 just died. I tried to start it, and it would die as soon as the choke was pushed in. That is until it wouldn't start at all. So what is the story?
MTMark is offline
post #5 of 6 (permalink) Old 07-28-2013, 08:04 PM
Carburators do that when the road is too steep. Fuel injection does not have that problem. Unless you have a pumper carb like in a chain saw the float bowl can get dry or the pick up point in the gas tank needs to have a tube with a weight on it to go to the bottom of tank. Nothing wrong with your fuel pump
bushpilot is offline
post #6 of 6 (permalink) Old 07-28-2013, 09:40 PM
Fuel pump?
-------it was the fuel filter! Should be changed during major servicing.
MTMark is offline
