Big bore cooling issues - Yamaha Rhino Forums - Yamaha UTV Forum
post #1 of 20 (permalink) Old 02-10-2009, 09:07 AM Thread Starter
Well I am new to this site but need some help. I bought an 04 with a blown motor. So I pulled the motor an went to rebuilding an upgrading, to start I went with a +4 mm stroker crank, a mudblaster cam, 11:1 JE +1mm piston, black rhino cdi, dg full exhaust, eliminated air box and running huge K&N. This thing runs great but it's running hot! Way hot! I have seen these shrouds and fan kits on eBay , and wondering do they work? Should I just fab up a huge radiator ? We do alot of trail riding so air flow is low ... Some help would be nice .... Thanks and great site!
here is what i started with, can you say JUNK!
and here is where it is at, its running and getting there.
my airbrushed dash I did.
Xtremetoyzracing is offline
post #2 of 20 (permalink) Old 02-10-2009, 09:30 AM
sandjunky's Avatar
what size is the piston? 105 or 102? i think a PWR rad. would help and also i would put the fan on a switch so you can turn off and on as needed.
sandjunky is offline
post #3 of 20 (permalink) Old 02-10-2009, 09:34 AM
Yes the fan shrouds work....but you may not have your system burped good. You may try doing that again. If it is I would reccomend going to a radiator that has a pass system. Alba makes one that I run with no problems. I think TCP makes one also. I'd start there
post #4 of 20 (permalink) Old 02-10-2009, 09:35 AM
The PWR is just a little thicker. It doesnt force the fluid pass thru.
post #5 of 20 (permalink) Old 02-10-2009, 09:37 AM
Agree, I run the TCP fan shroud and seems to work good for 50 bucks
note: are you sure the water pump is working correctly??? I have seen one of the tangs break off of and it will not spin very well.
post #6 of 20 (permalink) Old 02-10-2009, 09:44 AM
sandjunky's Avatar
also, how hot is hot? 225 or 275? big bores are hard as hell to keep cool. you can also try running engine ice or evans to help it from boiling.
post #7 of 20 (permalink) Old 02-10-2009, 10:50 AM
PROJEKT's Avatar
I have a 686 that runs no more than 210 deg. I have the stock rad w a fan shroud, 22-24 psi rad cap, water wetter and stock fan wiring. Some guys upgrade radiators, oil coolers, add a fan switch, but so far I have been OK.
Also, as mentioned, be sure you spend the time to remove all air from the system.
PROJEKT is offline
post #8 of 20 (permalink) Old 02-10-2009, 10:55 AM
I dont let mine get to 210.....to me...thats hot. I shut her down if I get it up that high
post #9 of 20 (permalink) Old 02-10-2009, 11:11 AM
I def would slow up to see if it would cool down also, at 210 or up.
I normally run 190 and no more with my 686 and tcp fan shroud even when in the 90's at the dunes
Projekt, you might want to relocate the oil cooler or add one inline like I did, this will take the hot oil air off the stock radiator and you will see the difference.
post #10 of 20 (permalink) Old 02-10-2009, 11:46 AM Thread Starter
more info
Ok, the motor is a 691cc now. I am running engine ice, alsoit is well blead of air. I think you guys got some great ideas I will try. Thanks
Any one big bore a 700 fi ?? wally Yamaha Rhino Performance Discussions 8 02-01-2009 11:26 PM
07 Rhino Starting issues... cp480 Yamaha Rhino General Discussions 14 10-05-2008 09:55 AM
Full Bore camo mosslager Yamaha Rhino General Discussions 14 08-08-2008 09:25 AM
