engine miss at high rpm - Yamaha Rhino Forums - Yamaha UTV Forum
post #1 of 20 (permalink) Old 07-23-2009, 10:53 PM Thread Starter
have an 07 rhino motor is stock. i am running a k&n filter,big gun exhaust,carb has been jetted,cdi box. rhino starts and idles like a champ but as u get 2 bout 40mph it will sputtr. it is really noticable n the neutral position or goin down hill. motor has 1600 miles on it. oil gets changed every 300 miles with filter spark plug is factory ngk and changed every 500 miles but is usually burnt pretty bad.fuel filter every 500 miles. tore carb down yesterday and is spotless.any suggestions on what 2 check next. run cheap gas is high octane gas betr or what about running seafoam 4 fuel treatment. oh yeah the sputr will not kill the motor just enouh 2 piss u of.
jonboy84 is offline
post #2 of 20 (permalink) Old 07-23-2009, 11:06 PM
isnt the 07 efi? if its carbureted i would say cdi or maybe just needs a fuel controller,,maybe fuel pump? I am guessing here
post #3 of 20 (permalink) Old 07-23-2009, 11:18 PM Thread Starter
gona put stock cdi back on n the morning and give it a try.is there a way 2 check fuel pump?
jonboy84 is offline
post #4 of 20 (permalink) Old 07-23-2009, 11:31 PM
I dont know a good test, do eveything else first? some cdi's came from the maufacturer not working right...I got a bad one and had a hell of a time figuring it out because I did a bunch of stuff at once.. didnt know which upgrade caused the problem, I also have a new fuel pump on there lol
post #5 of 20 (permalink) Old 07-23-2009, 11:39 PM Thread Starter
if cdi is bad this will b the 3rd box. 1st 2 boxes didnt make it a month this 1 has lasted awhile. if i do change out pump go back with factory pump or aftr market?
jonboy84 is offline
post #6 of 20 (permalink) Old 07-23-2009, 11:45 PM
the fuel pump discussion went down on utvunderground and they decided a stock was all you need.. i had already got a high flow pump from a vendor in Glamis, It was all he had and it works great, noticeable improvement from the first ride.
post #7 of 20 (permalink) Old 07-24-2009, 02:36 PM Thread Starter
not the cdi box put stock one back on still sputtrs at middle to high rpms. gona put stock jet back in and c what happens. thanks for the input so far.
jonboy84 is offline
post #8 of 20 (permalink) Old 07-24-2009, 02:40 PM
check all of the boots connecting the carb for tears or holes, check your exhausts for leaks at all connections.
and run min of 91 octane
post #9 of 20 (permalink) Old 07-24-2009, 02:44 PM Thread Starter
10-4 will do
jonboy84 is offline
post #10 of 20 (permalink) Old 07-24-2009, 02:57 PM Thread Starter
found a hole on uderside of the slip on exhaust. the hole is rite after where the 2 pipes connect is this supposed to b there and if not is it fixable and whats best way 2 fix.
jonboy84 is offline
