08 Rhino 700 - Won't idle and hard starting - Yamaha Rhino Forums - Yamaha UTV Forum
 1Likes
  • 1 Post By rmcelwee
post #1 of 9 (permalink) Old 09-09-2009, 10:03 AM Thread Starter
I live in Costa Rica, about 100 miles from the Yamaha Dealer. I shipped my Rhino here from the US. It ran fine for about 1500 miles. Now it won't idle when you come to a stop and it is very hard to start and dies. It will run down the road ok. I went through the onboard diagnostics and found no fault codes. The sensors checked out ok. I pulled the spark plug, it looked ok. I took off the gas cap and air filter element, but it still ran the same? Help! Anyone have any good suggestions?
Rory_y is offline
post #2 of 9 (permalink) Old 09-10-2009, 09:58 PM
What fuel are you running? Try a higher octane fuel, may just be low grade fuel causing the problem. Also, check your fuel filter it may be clogged.
wildbill23c is offline
post #3 of 9 (permalink) Old 01-02-2010, 08:35 PM
yes same thing with my 09 rhino under warranty dealer found bad wire, wire was broken inside insulation really hard to find, wire went into fuel injection body, after that was fixed my rhino runs like it was supposed to
rocko is offline
post #4 of 9 (permalink) Old 01-03-2010, 09:32 AM
there is no fuel filter on the 700....just a fuel pump strainer in the tank...... check your valve adjustment.......
ngk 9198 CPR7EAIX-9 iridium .......try this one for the 700 it helps with starting...........
rhinodad is offline
post #5 of 9 (permalink) Old 02-21-2010, 07:07 AM
bender.chris5908's Avatar
Garage
I have seen this problem in the past, i had one in the shop the other day.. same problem.. you can hook the diag tools to them and it won;t pic it up... this guy had a mouse problem in his batt box!
bender.chris5908 is offline
post #6 of 9 (permalink) Old 02-23-2010, 08:05 PM
hard to start!!!!
my 700 starts fine but idles to high found out that there is a valve that is bolted to the throttle body called the ICS valve when closed makes it it idle to fast. i bet yours is stuck open which will make it to hard to start and stay running the bad news is that to fix this you have to buy a new throttle body!!!!!! and that sucks !!!! so check that out hope it helps
khasler is offline
post #7 of 9 (permalink) Old 10-05-2017, 06:11 PM
Same issue on mine. Also had a mouse nest in the batt. box. Checked all my wires and they all seem fine. What was the fix on his?
rmcelwee is offline
post #8 of 9 (permalink) Old 10-05-2017, 09:59 PM
LBR
Administrator
LBR's Avatar
Unfortunately, he never did come back on and say what it was....but that was over 7 1/2 years ago too.
LBR is offline
post #9 of 9 (permalink) Old 10-06-2017, 09:37 PM
Noticed after posting that it was an old post. I swapped out my spark plug today and it fired right up.
LBR likes this.
rmcelwee is offline
