07 660 rhino backfiring thru carb - Yamaha Rhino Forums - Yamaha UTV Forum
post #1 of 4 (permalink) Old 10-09-2010, 11:50 AM Thread Starter
I have a 07 660 rhino with aftermarket cdi box and clutch sheave,everything else is stock. It will miss and backfire through the carb at low rpm's. I have recently changed the plug and it was black, also it smells like it is running rich. Any suggestions.
scottdawes is offline
post #2 of 4 (permalink) Old 10-19-2010, 09:43 PM
mine did the same thing until i rejetted the carb. i have stock exaust but i do have a air filter and cdi. the stock jet is a 145 and i went with a 150, it worked for me and it might work for you. also check your fuel filter and make shure its clean.
2005 Rhino 660
Big Gun cdi
Dyno jet kit
Uni air filter
Trail tec Vapor computer
Custom dash
huterworks overdrive clutch weights
4 150 watt KC daylighters
extra battery
55+ mph
SteveSmith is offline
post #3 of 4 (permalink) Old 10-22-2010, 01:42 PM
Unleashed UTV's Avatar
Sounds like jetting, but it could be valve adjustment. They tighten up as they ware and need to be adjusted to have some clearance.
Unleashed UTV
5838 N. 19th Ave
Phoenix, AZ 85015
602-246-4011
www.unleashedutv.com
Unleashed UTV is offline
post #4 of 4 (permalink) Old 05-11-2011, 07:12 AM
mine was doing the same thing. after much research I found a small hole in the main diaphram on top of the carb. I had to use a led light and a lot of stretching of it to find it but I replaced the diaphram and that fixed it
yamadog is offline
