Yea i thought toed out gives more stability but a little more bump stear. maybe i have it backwards. might explain why it is a little edgy to drive since i replaced the rack and toed it out about a 16th-1/4..... one more question for you guys... grease.... i am using 101 moly. and going to mix 1/4 anti sieze (my spelling sucks) we do it on the long travel rails, the molly seems to get real loose when ridden hard. or period just seems to get loose, the anti sieze tends to make it more sticky and stays together. any opinions?
Tow out is gonna make some twitchy tight turns , fun!!!(I run this way in my rhino and car) .. Most peeps set the tow in 2-6 degrees ..gonna make you go straight as an arrow and make thing more stable.. when the car pushes forward everything tightens up and you fo back to zero degrees.Thats my story and I'm stickin too it
if the front tires have power to them (in 4x4) they will pull what play there is from toe out towards in. In 2wd the drag will pull the toe out. I have't experimented alot on the Rhino, but I know on my jeep it can make things interesting in 4x4 on higher speed gravel riding as the front gest real quick to steer with the extra toe-in induced from the pull of the front tires.
It can get alot more complicated then that though from differences in circumfrences of the tires front to rear as a result of air pressure, loading or size. Personally I've set my Rhino and my buddy's to have under 1/4" in or 1/2" between front and rear of tire measurements. Works for us but most of our riding at speed is in 2wd.
As for grease, I have been using a Flamingo Oil Company moly that is the bombdigity. It doesn't mix with water, has a super high boiling point and seems to last forever and is a super pain in the ass to clean off any surface (high adhesion). Not too many retail joints north of South Florida stock the stuff, but it's what all the mud puppies in the south run in the ATV/UTV's and full size 4x4's.
Thanks for the info guys on toe in and out.. and specially on the grease. i am goint to try the toe in theory and then slowly change it to see which is better. i do allot of fast desert riding, and the dunes so we will see
Related Threads
118.2K posts
8.5K members
Since 2008
